Skid Control ECU "How to"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Euclides, Sep 26, 2019.
  1. Euclides
    Euclides New Member
    Brockton
    Hello All,
    Thank you for the site and help. I have used it in the past to troubleshoot.
    I'm currently seeking to replace a skid ECU on a 2005 Toyota Prius . I have the error codes in the photo.
    I have partially disassembled the dashboard .
    While disassembling, I noticed the skid control ECU can be seen from under the drivers side. I can unscrew the 2 screws at the bottom and remove the wires clipped in however is there a easy way to remove the top screw?
    if not, what should i do next? Continue to remove the dash or remove the steering wheel and column>
    Thank you,
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  3. Sharnold
    Sharnold Active Member
    400
    126
    Alabama
    Have you tried clearing the DTC or analyzing them with techstream before replacing the part?
