SKS default setting from dealer for driver's door
Discussion in 'Gen 2 Prius Main Forum' started by NuShrike, Dec 15, 2005.
  1. Yes, the driver's door unlocked all doors.
    0 vote(s)
    0.0%
  2. No, the driver's door unlocked only the driver's, although I may have changed it.
    100.0%
  1. NuShrike
    NuShrike Active Member
    1,378
    Simple question for a recent related topic to see how if it's a factory setting, or some savvy dealers mess with it before delivery.
  2. justinc
    justinc New Member
    70
    San Jose, CA
    No, my 2006 Prius SKS default only unlocked the drivers door.
  3. mitchbf
    mitchbf New Member
    105
    Chicago Area
    As I recall reading, this is the only choice you have, driver's door opens only driver's door. Now if you touch the passenger side or the hatch, all doors will unlock. Sometimes I'll use that feature if I'm walking by the car on the passenger side. Otherwise, I have to either pull out the fob or manually unlock the doors after opening the driver's door. <_<
  4. Wynder
    Wynder New Member
    254
    Bear, Delaware
    You can apparently go through the MFD diagnostic screen to change the behaviour to unlock all doors when you open the driver door.
  5. mitchbf
    mitchbf New Member
    105
    Chicago Area
    Is there a place with the detail on that? I'd really like to make that change. Thanks in advance.
  6. brandon
    brandon Member
    771
    Manhattan, KS
    No, through a certain combination of buttons on the fob, you can program it to unlock all doors when you grab the driver's door handle. That's how I have mine configured now. I don't have the instructions on me at present, but it is in the owner's manual.
  7. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Yes, your owner's manual.
  8. brandon
    brandon Member
    771
    Manhattan, KS
  9. mitchbf
    mitchbf New Member
    105
    Chicago Area
    Thanks Brandon. I'm from Kansas too! I had found the info in the other chat and printed it out. Your was much friendlier than Isr/America or whatever, and much appreciated, thanks.
  10. IsrAmeriPrius
    4,333
    Southern California
    I am sorry you took offense to my answer. You asked a question which implied that you were unaware that the instructions for the dance to change the SKS defaults settings were in the owner's manual. I gave you an accurate answer. I was neither pontificating nor lecturing at you. Next time, I will make sure to go out to the car, get the manual and copy the relevant portions of the instructions for your benefit.
  11. Tideland Prius
    16,445
    Here, I'll do it.
    Page 30:
    CHANGING THE DOORS TO BE UNLOCKED
    Each time you push the lock button
    together with the panic button
    on the smart key for about 5 seconds
    with the hybrid system off, the
    setting for door unlocking will change
    as follows:
    1. Driver’s door unlocking mode: If you
    perform smart unlocking operation on
    the driver’s door, it will unlock. Performing
    unlocking operation on the
    front passenger’s door or back door
    will unlock all the doors. When the
    system switches to this mode, one
    beep sounds inside the vehicle and two
    beeps sound three times.
    2. All doors unlocking mode: Performing
    smart unlocking operation on either
    front door or back door will unlock all
    the doors. When the system switches
    to this mode, one beep sounds inside
    the vehicle and two beeps sound twice.
    3. Single door unlocking mode: The
    driver’s door or back door on which
    you perform smart unlocking operation
    will unlock. However, performing unlocking
    operation on the front passenger’s
    door will unlock all the doors.
    When the system switches to this
    mode, one beep sounds inside the vehicle
    and two beeps sound once.
  12. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    2006, only the driver's side door.
  13. Kacey Green
    Kacey Green Member
    112
    Gainesville, FL
    I work for a Toyota dealership and I can tell you that all Toyota vehicles that we've recieved to-date with SKS have been driver's door only. The limited Avalon has it too.
  14. daniel
    14,487
    1,519
    Spokane, WA
    I bet they all come driver's-door-only from the factory, but some dealers change it, either intentionally or inadvertantly.
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i think my car was originally in driver unlock mode.. then i made it single unlock just to see.. and then i fell in love with all unlock.. so i left it at that.
    it's fun showing off this feature to non prius drivers :)
  16. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    There should be another poll options:
    No, the driver's door unlocked only the driver's, although I DID change it.
    That's what I would've picked.
  17. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    <div class='quotetop'>QUOTE(cwerdna @ Mar 13 2006, 03:11 AM) [snapback]224160[/snapback]</div>
    me too...!
    btw - on delivery, service dept said this COULD NOT BE DONE....hahahhahahhahha
