SKS Key fob usable with dead battery???
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Cadenza, Oct 7, 2014.
  1. Cadenza
    Cadenza Member
    124
    LALA Land
    Hi folks,
    I recently had an eardrum-blowing event with my Prius....
    After I pulled the key fob out of the slot and got out of the car, the alarm suddenly went off. I tried to push the Lock and then Unlock buttons multiple times to turn off the alarm but that didn't work. After I re-inserted the fob into the slot, the alarm turned itself off. Trying to lock the doors, I noticed the remote functions (Lock, Unlock, Panic) no longer work. When any of these buttons is pressed, the red LED light on the fob no longer lights up. However, I can still open the car doors/trunk with the fob in my pocket as well as start the car w/o inserting the fob into the slot.
    Is the battery in the fob dead? If yes, do the "smart" functions continue to work with a dead battery?
    PS: If the remote Lock/Unlock/Panic buttons is all I give up, then that's fine. I don't care to replace the battery every 1.5-2 years, even though I can do it myself. The "dumb" key fobs for my other cars (14 yrs old, 8 yrs old rechargeable) are still on their original batteries.
  2. JC91006
    16,482
    8,400
    1.You might have a stuck button on your fob.
    2. Bad 12v battery
    3. Bad fob battery
  3. Cadenza
    Cadenza Member
    124
    LALA Land
    I like multiple guess answers. #1 is correct... the 'panic' button was stuck. All buttons work now.
    Thanks!
