SKS Key Technical Question
Discussion in 'Gen 3 Prius Main Forum' started by Redpoint5, Jan 22, 2015.
  1. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    I bought my 2012 PiP with 1 key provided by the seller, but the key wasn't the original one issued to the car.
    I just spoke to the original owner of the car who has both original keys and is willing to sell them to me.
    Did the original keys get unpaired when the replacement key was issued?
    -Yes, the original keys were unregistered when the used replacement was registered to the car
    How are the keys paired? Does the car learn the key, or does the key learn the car?
    -The keys are paired by using Tech Stream and a mini-VCI cable. The car ECU learns the keys.
    If the original keys are no longer paired, how much are they worth?
    -Probably less than $50, but the owner thought they were worth more. I paid $100 each.
    I would just test the keys, but the woman lives 150 miles away. I'd like to be reasonably certain the keys will work if I make the trip.
    -The keys didn't work because they were unregistered from the vehicle. I could have used Tech Stream to see what keys were paired to the car. This would have shown me that only 1 key was registered.
    UPDATE: Keys there were original to the car can be registered back to it, even if a different master key is used.
    #1 Redpoint5, Jan 22, 2015
  2. JC91006
    16,482
    8,400
    how do you know the key you have now is not original to the car? Did you ask the original owner why they have the 2 originals and why it's not with the car?
    Instead of driving 150 miles, won't it be worth while to use the post office and get them shipped?
    #2 JC91006, Jan 22, 2015
  3. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    Sounds like a good deal to me. The original keyfobs should work unless they were deleted from the registration list on the car. Even if they were deleted, they could be added back with the chicken dance procedure. If they are truly the original keys, the mechanical keys are already cut for your lock.
    Redpoint5 likes this.
  4. Redpoint5
    1,026
    508
    Portland, OR
    I know the key I have isn't original because the original owner has told me she has both keys that came with the car, and did not surrender a key when the car was taken.
    My friend lives in Eugene, so it makes sense for me to kill 2 stones with 1 bird by visiting him and testing to see if the keys will work. If I have reasonable assurance that the keys will work, then I'll just have my friend pick them up now, instead of waiting until I can make it down there.
    It seems the keys would be worth substantially less if they don't work. What would it cost for me to purchase a new OEM key and program it myself? Perhaps $160? How much would it cost for me to purchase a used key from Ebay and have Toyota program it, assuming they even know how to do that?
  5. Redpoint5
    1,026
    508
    Portland, OR
    Any chance the locks were changed to match the replacement key? Do you know if it's standard procedure to delete prior keys when adding a new one? Finally, is the key programmed to the car, or is the car programmed to the key?
  6. Mike500
    Mike500 Senior Member
    2,593
    764
    You need to get one of those mini-VCI cables with Techstream software.
    You can then see if the original keys have been deleted . Then, you might want to add another key.
  7. bisco
    49,484
    boy, this is a tough one. would she consider sending one key for free to test, and then you pay for both if they work?
  8. mikefocke
    3,699
    1,645
    Sanford, NC
    Ridiculous that someone would keep a key to a car they didn't own. No earthly use to them. And unethical.
    So since she was forthcoming about the key you have not being one of the two originals there must be some story like a lost key or a family dispute somewhere along the line. Which implies reprogramming being done.
    PosauneGuy likes this.
  9. Mike500
    2,593
    764
    I would be very hesitant to buy anything from anyone whose car was probably repossessed for missing payments or some other reason.
  10. Redpoint5
    1,026
    508
    Portland, OR
    The car was reclaimed by the owner's insurance company after it was in a wreck. According to her, the insurance company said they don't need the keys or the charger to the car.
    The car was then sold at auction, repaired, re-titled, and now I own it. I found the original owner by looking up the address listed as "home" in the nav, and then looking the address up in the phone directory.
    Nothing fishy about this, the DMV has already issued the title in my name.
    #10 Redpoint5, Jan 22, 2015
  11. JC91006
    16,482
    8,400
    I'm still quite confused how you ended up contacting the original owner of the car. If this car was sold at auction, repaired, and then sold to you with a key that starts and seems to work properly. Why would anyone at that point contact the original owner of the car? Very strange how that happened.
    On the Gen3 cars, if the keys were lost (seems to be in this case at auction), the car would need to have been reseeded in order to get another key to work in the car. The reseed procedure would erase all existing keys so the 2 keys the original owner possess most likely will not work on the car now.
    Another way would have been to replace the entire system for the keys and another system with working keys get installed. This method will also make the 2 original keys non operable
  12. RobH
    RobH Senior Member
    2,369
    979
    70
    It sounds like the original keyfobs were deleted from the car registration. But the car id programmed into the keyfobs when they were first registered is still correct. The big obstacle with used keyfobs is the car id mismatch between the keyfob and the car. Since the car id in the old keyfobs still matches, a seed reset is not required to reregister them. A chicken dance, or a simple Techstream registration (without a seed reset) should work fine.
    I suggest offering the original owner $25 each for the keyfobs. You're probably money ahead up to $150 each. Ask a dealer how much he wants for an additional keyfob with programming and cutting the mechanical key. $200 for the keyfob, $60 programming, and $25 for key cutting wouldn't surprise me. A true stealership could easily double that...
  13. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The car is programmed to accept the fobs. The -key- is mechanical, and the locks would have to be changed to change that. But it's not rocket science to cut a mechanical key, so that has probably been done (your mechanical key does unlock the drivers side door?).
    I suspect her FOBs won't work unless you program them to the car. The mechanical key in the FOB would probably work to unlock the drivers side door.
  14. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    As per the original thread, the first owner still had their home location stored in the NAV. Word of advice: I use my town center for home.
  15. Mike500
    2,593
    764
    I use my nasty neighbor's address.
  16. JC91006
    16,482
    8,400
    I don't understand why it would be a problem using your own home address? Unless you didn't delete the garage door opener code, it shouldn't matter at all
  17. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    There are occasional stories (Or maybe just rumors? I haven't fact-checked.) of someone whose car is stolen while away from home, then the thieves use the navigation or the vehicle registration to find the home address, use the garage door opener to get inside (or break a window, since they know you're not home and have no car any more), and steal all your valuables too.
  18. Redpoint5
    1,026
    508
    Portland, OR
    I wish I had read your helpful reply before I went off buying the EVSE charger and keyfobs from the original owner. I purchased 1 charger and 2 fobs for $400, which is too much in hindsight. It's much less than the owner wanted for the items, but she was not in touch with the market value for used fobs and a charger that is universal. I bought a Leaf charger for $200 on CL just after negotiating the price for the original charger and keyfobs. Now I have 2 chargers.
    The keys I got from the original owner seem like a worst case scenario. Neither smart key works, and the physical keys are cut differently than the key I got with the car. I haven't tried the original keys in the door yet, but I'm hopeful they will work considering the physical key I have with the working smart fob doesn't open the door.
    I'm probably confusing things:
    1 smart key came with the car. It has a different physical cut than the other 2 keys. The smart key does operate all car functions properly. The physical key doesn't turn in the door handle (I'm assuming you turn the key just like a normal key, but it doesn't move). It does not have the remote AC button.
    2 smart keys were original to the car and no longer operate any function. I need to see if they still physically open the door. These have the remote AC function.
    Based on JC's comments, there are 2 remaining scenarios:
    1. A used keyfob was purchased that already had a key cut to the car it was being used in. It was reprogrammed to my car by a dealer or other authorized person that has access to the codes to do the key-reassign operation.
    2. A used kefob was purchased along with the electronic unit that resides in the car and is paired with that key. My car no longer has the original key system.
    If scenario 1 is true, then the original keys were simply deleted from the key registry of the vehicle, and another key was added. All I need to do is add the original keys back with some software or hardware that I can purchase relatively cheaply.
    If scenario 2 is true, then the original keys aren't associated to the computer currently in the vehicle. In which case, I have to get them reprogrammed to my car by a licensed locksmith or dealer at greater expense.
    Am I understanding this correctly? If so, what must I purchase to program the original keys back to the vehicle?
  19. JC91006
    16,482
    8,400
    Wow $400. You already had 1 working key, just needed to buy a "new" 2nd key. That would cost you about $125 on Amazon and you can program it yourself with ease. You would need to buy a MiniVci on Amazon for $25 to do it but that would do all your future diagnostics on the car too.
    Since you've already spent the money, go and buy the MiniVci and see if you can add those keys to your car.
  20. Redpoint5
    1,026
    508
    Portland, OR
    Yeah, in hindsight I spent too much. I had negotiated the price including the charger just after loosing 2 Ebay auctions for chargers that sold for $200. I figured the original EVSE charger was worth $200, I needed one, and there weren't other prospects on Ebay. The lady didn't want to let it go for so little, so I agreed to pay $100 for each keyfob thinking they would just work, and that I would have to pay a couple hundred to get a new key working anyhow.
    Well, $400 later I have an extra charger to take with me, and 2 keyfobs that may or may not be easy to add back to the car.
    Big thanks JC. I should have looked at your post before I finalized the purchase. My negotiating power was limited because I had a friend complete the transaction, since I live 150 miles away.
    I'll drop the 25 bucks and see how it goes. I'm assuming this cable/software should will work?
