SKS keyless start suddenly not working (and no its not the KEY button)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ianmeister, Jul 10, 2023.
  1. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    hello all. so I was tinkering with my 2004 US model trying to get a junkyard key to work on it. Now suddenly the original key (that worked fine up to this point) keyless start and "reach for the handle" unlock stopped working. I can lock the car from the buttons from a distance, I can start the car by inserting the key, but the keyless start just acts like there's no key in the car. And yes I tried the "KEY" button under the steering wheel repeatedly.
    TIA!!
  2. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,516
    Durham NC
    So now you have to insert the remote in the slot to start the car Is this correct?
  3. Tombukt2
    13,855
    2,516
    Durham NC
    While you're playing around trying to get this new fob working what are you using t i s software or? Did you have your remote apart at all? If so did you lose the little chip in the bottom of the remote?
  4. Ianmeister
    316
    319
    Meridian Idaho
    ok yes I have to insert it now, no I didn't take the original apart at all so I couldnt have lost the RF chip, I was following a youtube video on how to get your gen 2 to accept another key.
  5. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    You likely deleted the SKS programming.
    You can't program a used fob for SKS. You will notice in the video he clearly says he purchased a brand-new OEM fob from a dealer and it had never been programmed.
  6. Tombukt2
    13,855
    2,516
    Durham NC
    Yeah one locksmith told me the little tiny transponder chip in the bottom of the remote only works when insert it into the slot kind of like my Italian motorcycle everything else I guess is handled by the green board which is numbered and has something to do with the white box behind the cup holder in the console. So TIS can't even do this function?
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    I second the opinion that you managed to erase the working fob from SKS.
    At this point you are looking at having a dealer or capable locksmith program fobs to get SKS working. They would get a special code that "resets" the smart key (certification?) ecu. I have read (but do not know) that going this route allows used fobs to be programmed.
    The DIY (chicken dance) procedure or a capable scantool can be used to add a NEW fob but requires that you have one fully functional fob.
  8. Tombukt2
    13,855
    2,516
    Durham NC
    Seems to me if you were able to catch a car coming into LKQ with this option like I regularly see if you got the key fob or fobs and you got the white box behind the cup holder for the rear passengers from the console you would have a matching business It seems like there may be another computer in there too The security computer or whatever it's called so you get that one too and then the fob with the car goes with the white thing in the console and the other computer wherever it is and you have them then that should just plug into your car maybe need TIS to make something recognize something else but I'm thinking probably not and then that fob that went with those parts should work You could probably get all those parts at LKQ for next to nothing because to those guys that stuff is kind of worthless believe it or not
  9. dolj
    dolj Senior Member
    8,640
    4,391
    The white unit in the console does have something to do with the SKS, but it is not the certification ECU. Toyota calls it the indoor electrical key oscillator. Its function is to detect that the key fob is in the car.
  10. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  11. Ianmeister
    316
    319
    Meridian Idaho
    OHHHHHHH! ok, well then sounds like i pooped on the floor and slipped in it then!
