SKS not functioning right
Discussion in 'Gen 3 Prius Technical Discussion' started by getitinwriting, Oct 24, 2009.
  1. getitinwriting
    getitinwriting New Member
    Arizona
    Brand new 2010 III...so far I'm loving it. (Big improvement over my smelly 09.) But I'm having a weird issue with my keyless entry:
    If I touch the sensor to lock the driver's door, I get a long tone that doesn't stop until I press the button on the key fob. (It's the sound you'd expect if you tried to press the lock button on the fob with a door still open...but the doors are all closed.)
    If I try to open a door (any door) with the fob in my pocket, it doesn't work.
    IOW, the only way to open or lock my doors is with the fob.
    I tried the trick on pg 48 of the US manual, but no change.
    I can take it back to the dealer next week, but just wondering if anyone has any ideas and/or experience with this.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Is the other key stored inside the car? If so you need to wrap it in foil to block block the radio signal.
  3. pinzvidz
    pinzvidz Junior Member
    72
    Australia
    Yep, other key fob will be definitely inside the cabin, unless the OP has the key fob and is trying to lock the car with the ignition still in an "on" state?
  4. getitinwriting
    Arizona
    Doh! Yes, I've had the car for only two days, and the second key fob was still in the plastic envelope with the manual. How st00pid of me. Thanks, gents.
