Slashdot discussion of "sudden acceleration"
Discussion in 'Gen 3 Prius Technical Discussion' started by mmurphy, Nov 4, 2009.
  1. mmurphy
    mmurphy Junior Member
    42
    Akron, OH
  2. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I can tell you that, from my 8-year tenure as a service writer, if a DBW system detects any anomalies in any redundnacies with itself, the engine will not come off of idle. No amount of gas pedal application will change that.
  3. mmurphy
    42
    Akron, OH
    Allong the same lines, according to David(45671) on the slashdot thread:
    I have first hand hacking experience with the drive by wire throttle because my Grand Challenge team automated a Toyota Prius for the last Grand Challenge. There are 2 completely independent signals that go from 2 independent sensors on the pedal to the computer throttle component. The signals have to move in lock step with each other or the computer will detect a fault. If a fault is detected the throttle goes completely off and the car has to be turned off and turned back on to recover.
    So for the throttle to stick down both pedal sensors have to fail in the same way at the same time, which seems highly unlikely to me. Or there could be a bug in the computer control section, bus as a software engineer I can assure you that that would be impossible. ;-)
  4. bottomfeeder
    bottomfeeder New Member
    Chicagoland
    ABC Nightline Segment, 11/03/09
  5. TheForce
    3,461
    537
    Wheelersburg, Ohio
    This reminded me os a TV show I seen on FOX a LOOOONG time ago about cars going crazy. It was something about the CAT that made the cars crazy. When the CAT was removed or something the car would crash straight into a wall then reverse into another wall then drive forward again into the wall. They would spin out and flip over. It was all FUD to try to get rid of the things or something. I dont remember the name of the show.
    This "Toyota problem" is going to be 1 of two things.
    1. Its a real problem. Its going to be like one of those very rare computer problems that you just cannot replicate over and over again to find the cause. Stuff like that usually never gets fixed because it so hard to find the problem.
    2. This is all FUD to make Toyota look bad and to get people to buy American.
  6. chrisj428
    680
    144
    35
    Vernon Hills, IL
    Everything old is new again. It was driver error in the '80s with Audi and I'm supremely confident it will end up being that now.
    (Edit: Was it ABC which started the Audi 5000 witchhunt or was that CBS?)
  7. bac
    bac Active Member
    863
    52
    Pennsylvania
    I came here to say just that - Spot On!
    -Brad
  8. bwilson4web
    15,400
    For the accelerator rebuilding project Doug lets me carry forward:
    Accelerator Experiment
    Comparison of NHW11 and NHW20 accelerators:
    Example of the NHW11 performance after repair:
    This was from a unit with a 'bent' cam follower:
    Before and after contact cleaning:
    One accelerator that had a bent cam follower:
    Unit has been repaired but it part of my experimental set:
    Accelerator test jig:
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Actually the Audi fiasco was found to be caused by driver error induced by having the throttle and brake too close together. So it was an ergonomic problem.
    I suspect the "Toyota problem" is caused by people, period. I have never, and never expect to, have a problem with "sudden acceleration", brake failure, the car accelerating suddenly during braking, or any other small brain induced or imagined failure.
    The Prius is a computer system. The operator has absolute control. If the car isn't doing what you want, you can always shut it down (hold power switch down for 3 sec. - just like -any- computer made will do and has done for the last 15+ years.
    So "hey bud, what's your problem"?
  10. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Not to argue, but I don't think the Audi "problem" was ever resolved. I believe the most logical conclusion was that the brake pedal and gas pedal were is a slightly different position than most cars, but I don't think it was ever "proved". I believe the problem went away on it's own as there was never one to begin with, but not before absolutely trashing the re-sale value of an Audi first.
  11. rachaelseven
    rachaelseven New Member
    616
    211
    Adams, MA
    At the risk of being accused of :tinfoil3:, I would suggest that Toyota's "sudden acceleration problem" has a lot more to do with GM's sales numbers than it does with Toyota's cars.
  12. chrisj428
    680
    144
    35
    Vernon Hills, IL
    I can't remember in which magazine I read it years ago (Automobile or Car & Driver) where they put unsuspecting people in different cars (including a 5000 Avant) to get their impressions on subjective concerns. At random times, they could trigger a "blip" in the Audi's throttle to see what the driver would do. Typically this was done while the driver was performing an "agility and visibility" test by doing a reverse slalom through a set of cones.
    Unfailingly, the drivers would attest they had the brake pedal all the way to the floor and, unfailingly, photo evidence showed the brake lights were unequivocally off. Sure, there may have been ergonomic issues which predisposed the vehicle to pedal misapplication. However, at the end of the day, it was driver error at the root of the cause and not some demonic possession which caused the 5000 to rocket off into the pachysandra at breakneck speeds, mowing down small children on tricycles and the elderly crossing the street with their walkers in the process.
  13. richsc
    richsc New Member
    59
    Washington DC
    Not related to the floor mat thing, but I've noticed when the car is warming up that there is a slight surge acceleration at about 20mph. I have only noticed it twice and it's only slight, say 1mph, but disconcerting.
  14. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    If there really is a problem with the Prius drive-by-wire throttle, we're in deep doo-doo. Almost every new vehicle on the road now, foreign and domestic, uses drive-by-wire throttle and CANBus. The newest cars use FlexRay, an evolution of CANBus
    I have no doubt that out of hundreds of thousands, or perhaps a million vehicles, a handful won't have some sort of glitch. Nobody can guarantee anything to be 100%
    In that context, until it happens to you, runaway cars are a statistical oddity. Thanks to the (lack of) driver training these days, nobody knows how to change a flat tire, operate a stick shift, properly park on a hill (Hint: wheels turned IN or OUT?), or shift a transmission into neutral
    I've had direct personal experience with a WOT runaway, but that was around 25 years ago. I helped a buddy rebuild a 350 V8 to put into a '69 Chevy C10 pickup, which had originally come with a 327
    To save money, he reused a lot of parts, especially the carb return spring. Everything went together fine, fired right up, we then took it out on an isolated road to break it in
    He hit the pedal a little harder, and suddenly all four barrels were wide open. He shifted into N, killed the ignition (Flooded the engine too, as the carb was still wide open), and we coasted to a stop in the rich smell of gasoline
    The return spring had broken right by hook which goes onto the carb throttle lever. I held the carb wide open while he cranked it. When it finally fired, I snapped the throttle closed, then we turned around and slowly putted back to his place. Easy solution: new return spring
    The other experience wasn't as dramatic. The Ford work truck at my hobby farm uses a throttle cable. After +20 years, it became frayed and would sometimes stick at around 1/3 pedal. The solution was simple: a new throttle cable
  15. rachaelseven
    616
    211
    Adams, MA
    And if there isn't, which is much more likely give the fact that no such problem has EVER been demonstrated, this whole thing is just a few jammed floor mats, a few bad drivers, and a whole lot of media scaremongering to drum up ratings... result of which will be that Toyota will get an unearned bad rep, the resale value of our cars will be destroyed, future models will be crippled somehow, and a whole bunch of unscrupulous lawyers will get rich.
  16. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    This story sounds familiar. Hmm, oh yea, now I remember: silicone breast implants - huge media uproar, people screaming, lawyers and big class action suites, companies bankrupted, all without scientific evidence. When the evidence did come in, it vindicated the now bankrupt companies, not that it did them any good.
    Tom
  17. a64pilot
    771
    62
    Albany Ga.
    Seems to be a common thread doesn't it?
  18. TopJimmy5150
    TopJimmy5150 Junior Member
    55
    Gillett, PA
    I had this happen to me the other day....it scared me a little. I was coming to a stop over some rippled pavement on a downward slope and I noticed the CHG section of the display bar was lighting up and then the car surged forward for just a second with very little break control. If there was someone in front of me it would have been a hit. Be very careful slowing down on rippled pavement!
  19. qbee42
    18,058
    3,073
    Northern Michigan
    This issue has been addressed many times on several other threads. The short answer is that your Prius didn't "surge forward". What actually happened is a loss of braking traction which caused a transition to ABS braking. The momentary reduction in braking effort feels like a surge forward, but it isn't. At no time did your Prius gain speed. In fact it was slowing down the whole time.
    Tom
  20. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    I wish I could disagree with this but experience says you are spot on.
