Slight 2011 Prius change...
Discussion in 'Gen 3 Prius Main Forum' started by SW03ES, Jan 29, 2011.
  1. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Hey All,
    Went to the DC car show today, had several 2011 Priuses as well as a Prius V and a Prius C. I did note one nice change to the 2011, there is a piece of brushed stainless trim down the bottom of the doors with "Hybrid" embossed in the back end of that trim on the rear doors, similar to the trim you see on the new Lexuses. I thought it did a lot to spruce up the car. Other than that everything was carried over.
    Liked the Prius V too...
  2. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    don't worry.
    if it's held on by adhesive tape we can pull it off
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    It's a Toyota accessory. I've seen it on one Prius at Fremont Toyota.
  4. SW03ES
    2,480
    176
    Gaithersburg, MD
    I'm sure its just adhesive tape.
    Could be an accessory, but every Prius at the show had it, there were 5 maybe.
  5. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    If that's the only sparkle I'm glad the 2010 is at par with the 2011.
  6. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    check www.toyota.com it's called a lower rocker molding.
    Would be idiotic if they put it on every car. I wouldn't want it.
  7. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Doesn't mean it's a new change for 2011. They could've just put the accessory on all of them for the show.
  8. Thai
    Thai Prius Neophyte
    1,197
    89
    It does look nice on a darker car. I am tempted to get it, but it is kinda redundant because we have a pretty big "HYBRID" emblem on the side of the car already. The HS250 has this molding, but it does not have "HYBRID" emblem like we do. So, i am holding off on the molding.
  9. SW03ES
    2,480
    176
    Gaithersburg, MD
    You can always remove the Hybrid emblem thats on there from the factory and use this trim. I think the trim really dressed up the car.
  10. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Not a bad idea if you're really into that accessory. I agree having two Hybrid emblems on the same side is overkill.
  11. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    Yes, and it will certainly throw off the balance and wear tires on that side more than the other side.
