Slight death rattle at start after sitting several days
Discussion in 'Gen 3 Prius Main Forum' started by Cheryl A, Dec 5, 2024.
  1. Cheryl A
    Cheryl A Junior Member
    Hi. Big fan of this forum so I thought I’d throw this theory out there.
    I had the head gasket changed by Tampa Hybrids as I was experiencing the rattling about a year ago. So far so good. I noticed a slight smell of antifreeze so not taking chances…before the head gasket ruined the motor. (Also changed ignition coils at that time)
    2010 has 260,000 mi but otherwise running great now.. On to a few weeks ago…
    The last couple months the rattle occurred 2x on cold start. Put some acceleration to it and went away quickly.
    As a former mechanic I have a question about a theory that one of my injectors is dribbling raw fuel into a cyl temporarily fouling a plug for a few seconds…
    Anyone hear of this? I might add my mileage dropped a few mpg during that time.
    Do the injectors wear out and cause this sort of thing?
  2. Brian1954
    Brian1954 Senior Member
    1,559
    606
    South Central PA, USA
    Take it to Tampa Hybrid to diagnose the current problem.
    ASRDogman likes this.
    50,782
    Sometimes it’s just unburned hydrocarbons leftover from a previous short engine cycle
  4. Mendel Leisk
    40,207
    Or water droplets that collect in the EGR. I've noticed such droplets, taking off the EGR pipe (between EGR valve and intake manifold). I did get a cold-start shake once, after the engine had just run a few seconds, the previous day.
  5. BiomedO1
    BiomedO1 Senior Member
    2,557
    1,371
    SacTown, Ca
    You live in Florida, a high humidity climate. It's more likely @bisco & @Mendel Leisk are correct, a few rough startup after high humidity days are one-offs IMHO. If the issue becomes more chronic, then you probably have issues.
    Dump some concentrated injector cleaner in your tank, on your next fill up - to nip the possible leaky injector issue - which I doubt... More likely you just got some bad fuel. You fix that by fueling up at high traffic gas stations. Fuel doesn't just sit around and has a lower likely-hood of getting contaminated.
    Hope this helps.....
    Brian1954 likes this.
  6. Tombukt2
    Tombukt2 Senior Member
    11,547
    2,026
    Durham NC
    And if you're sitting in the car and no this is going to happen you can immediately be giving it the gas and this would not happen correct You get off idle and the rattling is immediately gone?
  7. nicoj36
    nicoj36 Active Member
    515
    161
    If you know its going to be really cold the next day, try taking off the coolant reservoir cap briefly to release pressure then put it back in. It should help with the rattles.
  8. Mendel Leisk
    40,207
    Did Tampa Hybrids also clean the EGR system, say in the course of the head gasket replacement? I'd suspect they did; they're on the ball.
