Slight vibration - 50-55mpg cruise. Goes away with accel/decel
Discussion in 'Prius v Main Forum' started by andrew stuebs, Apr 18, 2022.
  1. andrew stuebs
    andrew stuebs New Member
    Jonesborough, tn
    2013 Prius v wagon
    2013 Prius V. 247k miles. New engine.
    I’ve got a slightly vibration/shudder only when cruising and going slightly uphill at 50-55mph. When I push down on accelerator or let off it it’s gone. Vibration is felt in the floor and in the consol. Nothing in the steering wheel or pedal.
    Thoughts?
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,718
    Texas Hill Country
    I might start on the motor mounts and then the suspension. Depending on who did the engine, they may have removed the subframe, suspension, cv axles and mounts.
    Air_Boss likes this.
  3. andrew stuebs
    Jonesborough, tn
    2013 Prius v wagon
    If it were suspension related why would it go away with the slightest increase in acceleration or deceleration? I haven’t changed transmission fluid yet. Is it possible it’s that?
  4. rjparker
    7,977
    4,718
    Texas Hill Country
    It would be those items because they were messed with...
  5. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    NO
    Hope you don't have to separate the engine and trani.....
    Is this the original trani?
