Slightly "Rough" Idle at standstill w. Low Traction Battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Canard, Oct 3, 2024 at 8:44 AM.
  1. Canard
    Canard Member
    214
    39
    Ontario, Canada
    I have a bit of an odd one...
    2010, 415k km (257k miles)
    Here's the scenario:
    -Stopped in traffic (vehicle stationary)
    -Engine is hot/warmed up (have been driving for a while)
    -Traction Battery eventually drops down to two bars (low)
    -Engine comes on to charge up traction battery
    -Engine sounds like it is revving at a slightly different rpm than normal idle (maybe a little slower?)
    -Engine sounds a little "rough"
    Once the battery gets up to 3 bars again, the engine shuts off... and if I drive off at any point and the engine kicks on, everything sounds fine/smooth.
    I'm wondering what is causing this slightly rougher idle in this exact specific scenario.
    #1 Canard, Oct 3, 2024 at 8:44 AM
  2. Mendel Leisk
    39,021
    I’ve experienced the same, would suspect it’s normal.
    Canard likes this.
  3. Brian1954
    Brian1954 Active Member
    998
    358
    South Central PA, USA
    This also happened to me a year or two ago when I had the AC turned on. It is not usual for me to be stopped in traffic for long periods of time. It has not happened again, so I am not concerned.
    Canard likes this.
  4. Canard
    Canard Member
    214
    39
    Ontario, Canada
    I took a look again this morning, and noticed the grey "Hybrid Synergy Drive" cover was rattling around pretty good at this lower-rpm idle, so I'm wondering if it's just a resonance thing that specific engine speed. It went away entirely (cover didn't rattle) when the engine bumped up in rpm slightly after the battery was 3+ bars...
  5. BiomedO1
    BiomedO1 Senior Member
    1,680
    868
    SacTown, Ca
    Check and clean out your throttle body and air intake pathway. A sticky throttle body flap would cause this. As for the engine 'beauty" cover; I always remove them and store it with my maintenance parts box. I prefer to see problems that may be masked by that cover and takes away the roof of a mouse house.:cool::whistle:
    On my old Prius C, the idle should be slightly faster than normal, when it's recharging a low traction battery. When was the last time the engine was tuned up? You may also have a weak cylinder that can be verified by looking at the spark plug and/or bore scope. That's a pretty objective test. A quantifiable test is compression and leak-down test.
    Hope this helps.....
    Canard likes this.
