Slip Indicator Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by heliotropehead, Jan 9, 2005.
  1. heliotropehead
    heliotropehead New Member
    701
    New Orleans, Louisiana
    Thrice now my car has jerked right then left for no apparent reason. All three times the slip indicator warning flashes for several seconds and then disappears. I'm just worried that there's something more to this. Today when it happened I was going 35mph, road & weather conditions were perfect & I honestly did nothing wrong. The only this I can come up with is right before the car jerked, I went over a slight bump in the road. Still, I remained in control the whole time. Is this normal?
    Thanks!
  2. removeum
    removeum Member
    407
    El Paso, TX
    8) heliotropehead,
    Is it possible that you hit some patches of ice and/or wet pavement and if so, that might be why the TC kicked in?
    Ben
  3. heliotropehead
    701
    Nope. Do you think a pothole would do it? Louisiana roads aren't the best!
  4. removeum
    removeum Member
    407
    El Paso, TX
    8) Yes I think a pothole could do it. What part of Louisiana? I lived in Oakdale, LA for 13 years before transfering here to Omaha, NE.
    Ben
  5. heliotropehead
    701
    Originally from New Orleans, schooled in Lafayette, now living in northern LA but considering a move back to New Orleans.
  6. removeum
    removeum Member
    407
    El Paso, TX
    8) I do miss my friend, bass fishing, (cushanda layes) I know spelled it incorrectly.
  7. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(heliotropehead\";p=\"62618)</div>
    It's happened to me a few times, at the same exact spot about a quarter mile from my house. The bump must cause a wheel to become momentarily airborne, which must have the same characteristics as slippage as far as the Prius' computers are concerned.
  8. Tideland Prius
    16,153
    A quick bump over railway tracks at crossing (when wet) will trigger the TRAC.
  9. DaveG
    DaveG Member
    806
    Vancouver, BC
    It's also happened to me when I went over a manhole/utility cover and one wheel spun-out slightly because of water on the metal.
    Dave
  10. Ceres
    Ceres Junior Member
    35
    2011 Nissan LEAF
    A similar thing happened to me today. I was braking for a red light when I hit a bump in the road, and all of a sudden I lost control of my car for a couple of seconds as it veered side to side slightly. The Slip Indicator Light flashed a few times afterward, then went off. I drove over this bump almost daily and this is the first time I lost control. It was quite scary, felt almost like I was hydroplaning at a low speed, but the road was dry and weather was sunny, so it must have been the bump in the road. I just hope I can avoid having this happen the next time. :frown:
  11. Patrick Wong
    18,200
    6,474
    Have you checked the tire tread depth of your tires, especially the front tires? My guess is that they are sufficiently worn to allow the tire slip. If you get new tires then this problem will likely go away.
  12. ualdriver
    ualdriver Member
    358
    62
    Midwest US
    This happens to me all the time when I brake on a bumpy road with the Prius, especially if you hit a good sized bump in the road. It also happens to our other cars as well. I wouldn't say I lose control, but the brakes definitely feel like they "let go" for a second. It's a long second.
  13. Ceres
    Ceres Junior Member
    35
    2011 Nissan LEAF
    The treads are still good, so I don't think it was a tire problem. I used to drive a Honda Civic and Toyota Corolla before my Prius, and I have never experienced something like this on a dry pavement and at such a low speed in those cars before. I'll just have to be more cautious with my Prius driving over bumps from now on.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The transition from regenerative braking to friction braking makes it feel worse with the Prius.
    Tom
  15. i3akachan
    i3akachan i love my new prius:)
    La Jolla, CA
    so i have a gen 3, and i was just reading the manual for fun...
    it says that if u're braking, and u depress the brake pedal all the way down and hold for 2 seconds, the anti-slip thing will come on. maybe when u go over bumps, the car thinks ur foot is flooring the brake pedal (b/c the car goes up, and ur foot stays at the same place), and turns on the anti-slip.
    no idea if this is the case, but that's my theory, since it looks like it happens in perfect conditions.
  16. Tideland Prius
    16,153
    Don't confuse it with Hill-Start Assist which is activated when you're stopped and you press the brake pedal past a "denté" or a threshold.
