Slip warning Only
Discussion in 'Gen 2 Prius Main Forum' started by Paul Schenck, May 7, 2020.
  1. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    Yesterday after having my alignment done at Les Schwab all seemed well. The next morning the slip light came on just as I began going 35 mph something I have not done on the very short drive home after the alignment. At the first stoplight the incessant beeping and the light went out, only to start again when I accelerated past 40 mph.
    This did not continue all day but stopped about 10 miles later, or 30 minutes.
    It has continue doing this every morning for the past three.
    I’m very excited about this because it is a problem that I have never had to repair in the over 600,000 miles that I’ve driven my 2005 I call Electra.
    I’ll let you know what I find out, however, if anyone has any insights they want to share I would appreciate them.
    iPhone ?
    SFO likes this.
  2. ChapmanF
    15,581
    Makes me think of wheel speed sensors, but we'll see what you find....
    jerrymildred likes this.
  3. dolj
    dolj Senior Member
    7,651
    3,860
    Wellington, New Zealand
    If you can share the codes, we might be able to share some insights. :sneaky: (y) :ROFLMAO: :LOL:
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Could also be bad wheel alignment or steering zero point correction not done after alignment.
    Paul Schenck likes this.
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Vehicle alignment CANNOT cause this, but you are 100% correct that an off-center steering wheel can! Most shops DO NOT properly re-center the steering angle sensors after an alignment.
    Davidude likes this.
  6. valde3
    2,002
    745
    Finland
    Newer really tested it on a Prius but at-least on Audi A4 bad aliment could cause this slip light to come on at speed. But anyways steering wheel being on center is part of a wheel alignment and so could the steering zero point calibration be. So in that sense those being wrong is a bad wheel aliment.
  7. 05PreeUs
    1,097
    563
    MSP
    Do you understand why that is? You are confusing the procedure and the result.
    "Wheel" alignment has nothing what-so-ever to do with centering of the steering wheel or steering angle sensor. Sure, when toe-in is adjusted as part of a total vehicle wheel alignment procedure, it can and often does cause the SAS to be off. This is not because of the vehicle wheel alignment itself, but because of HOW it was performed. Put another way, performing a vehicle wheel alignment SHOULD NOT affect the SAS and improper procedures are almost assured to.
  8. valde3
    2,002
    745
    Finland
    No I'm not confusing these two. Wheel alignment can mean procedure or result.
    If a steering wheel is not straight after wheel alignment it's not a good wheel alignment. So in that sense it's a part of wheel alignment. If the steering wheel was straight before wheel alignment and wheel alignment is done right of course it won't effect steering angle sensor.
    Think about this. If a car comes into a wheel alignment with steering wheel not straight and you do the wheel alignment and while at it also correct the steering wheel to be straight. Then putting the steering wheel straight was part of a wheel alignment. After that you might have to do the zero point calibration if it was calibrated with the wheel not straight.
    #8 valde3, May 8, 2020
  9. Paul Schenck
    523
    306
    Fresno, California
    Some good input I’ve been driving it for a few weeks now noticing how it performs and I realized I should fill in some info.
    When I replaced the engine in 2018 I had trouble reconnecting the steering linkage. This made the steering wheel angle off ( 11:00 not 12) I drove it this way and finally took it in for alignment. That’s what started the Slip problem.
    I suppose my smart nice person solution of having the alignment mechanic fix the problem I created was my first mistake. Of course my second was not giving you all the information.
    iPhone ?
  10. Paul Schenck
    523
    306
    Fresno, California
    No codes dolj
    iPhone ?
  11. Paul Schenck
    523
    306
    Fresno, California
    Steering Zero Point correction? This sounds right. What can you tell me about it??
    iPhone ?
  12. Paul Schenck
    523
    306
    Fresno, California
    05preeUs
    I had incorrectly connected the steering linkage back in 2017 drive it since then with the steering wheel at 11:00. The shop centered the wheel when they did the work and the problem started.
    iPhone ?
  13. Paul Schenck
    523
    306
    Fresno, California
    Valde: I think you nailed it how to do a recalibration would be my next step?
    iPhone ?
  14. Mendel Leisk
    38,715
    This might be what you need, not sure. Requires Techstream?
  15. Paul Schenck
    523
    306
    Fresno, California
    Thanks Mendel I’ve got it just never got it to work maybe today is the day
    iPhone ?
  16. ChapmanF
    15,581
    A caution: the steering angle sensor is an input to the vehicle stability control, and yes, having the VSC know what sensor reading is 'zero' is useful for the VSC to do its fancy stuff ... but if the steering linkage was at one point mechanically reassembled off center, changing some numbers inside the skid ECU isn't going to change that.
    There is an important mechanical relationship to establish first, where the steering wheel has equal travel to the left and the right from the point where the steering rack is centered and the car drives straight without the tie rod lengths having to be adjusted more than 1½ mm different from each other.
    If that mechanical relationship isn't established, somebody's going to have to undo that linkage and put it together the right way first, and then let the ECU work out where zero is.
