Slipping transmission
Discussion in 'Prius c Technical Discussion' started by Tim bowdoin, Mar 20, 2022.
  1. Tim bowdoin
    Tim bowdoin New Member
    Lake City, Florida
    2015 Prius c
    I own a 2015 prius c 2. The tranmission is sliping when I decelerate and is getting worse. I'm a door dasher so this is very important to me. I heard that a new auxiliary battery might fix it. Or maybe a transmission flush.
    49,488
    i don't think you are describing the symptoms correctly. can you provide more detail?
    if there were a tranny or battery problem, you would have trouble lights.
    how many miles on her?
  3. ChapmanF
    15,614
    Even in conventional transmissions, decelerating would be a pretty weird time for a transmission to slip.
    And in a Prius transmission, there is nearly nothing that even can slip.
    Can you take a step back and describe exactly what you notice the car doing, at the times when you describe it as "slipping"?
  4. jdenenberg
    jdenenberg EE Professor
    3,852
    1,847
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you are slowing down using regenerative braking and a wheel loses traction due to a bump or gravel, the computer will shut down regenerative baking for a very short time. You could perceive the change in deceleration as a slippage or even (as some have in the past) an instance of "sudden acceleration.
    JeffD
  5. bisco
    49,488
  6. Tim bowdoin
    Lake City, Florida
    2015 Prius c
    Thanks for the input. When the car is cold the rpms don't race. When I punch it. It happens when the engine is hot. The rpms spike and slowly go down after I let off the gas.
  7. Tim bowdoin
    Lake City, Florida
    2015 Prius c
    When the engine is cold it runs fine. I don't know what specific info yall need
  8. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Start by cleaning the battery cooling fan and its ductwork under the left rear seat.
    If the battery can't cool itself properly, the car will drive weird. The battery breathes cabin air, so the cooler you keep yourself, the cooler the battery is.
    Eventually the battery wears out and then the car drives even weirder.
    dig4dirt likes this.
  9. bisco
    49,488
    how many years and miles have you owned her?
    has she had all regular maintenance?
    are there any strange sounds you can record?
    any trouble lights on?
    when did the misbehavior begin?
    unfortunately, nothing in your description is helpful for internet diagnosis
  10. ChapmanF
    15,614
    Maybe we need to begin by asking what are this car's pronouns?
  11. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Never anthropomorphize your car. They hate when you do that. :D
  12. bisco
    49,488
    cars are female, there's no getting around it
  13. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Normal to have high revs when decelerating
    Gale Hawkins likes this.
  14. Matt H
    Matt H Active Member
    164
    104
    Okinawa Japan
    2012 Aqua
    Late response, but this is a symptom of a "tired" battery. There's something the hybrid system doesn't like, so it's going into a sort of battery preservation mode, where it will neither charge nor discharge the battery. Like Leadfoot said, it could be as simple as overheat, where the battery fan duct has a plastic bag obstructing it.
    Chances are, if you look at a scan tool, you'll see a pending P0A80 code. This is a two trip code, so it has to happen twice within a set time to become a permanent code and turn the money light on. The good news is that if this is the case, it sometimes will go another couple of years before giving up.
    Also with a good scan tool, you can look at the freeze frame data for the pending code. It'll show the highest and lowest battery block voltages. A 1.2V difference will set this code.
  15. ChapmanF
    15,614
    I think in this thread we've been gynomorphizing them.
    CR94, mr_guy_mann and jerrymildred like this.
  16. jerrymildred
    11,511
    14,113
    Tampa, FL
    That description does seem to be a little more precise. :LOL:
