SLLC Crystals
Discussion in 'Gen 4 Prius Technical Discussion' started by AzWxGuy, Oct 9, 2022.
  1. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    This has been a curiosity of mine for a while now, so I figured I'd post the story and see what anyone else thinks. I have already searched the forum extensively and can find only one mention. Years ago I purchased a gallon of the Toyota SLLC 50/50 pre-diluted antifreeze to use for top-up. I have about a half gallon of it left in the original container that is kept in an outdoor storage area but tightly capped. I'm not sure how old this stuff is or whether there is a shelf life to be concerned about.
    Several years ago I was going to top up the overflow tank in my 2011 Gen III. I think it might have been in early Spring when it was a little cold outside, but I don't think that had anything to do with it. I agitated the container and poured out a quantity of SLLC into a smaller container. I noticed it looked a little strange. There was what appeared to be a layer of long, branching pink crystals floating on the top of the pink fluid. I held the container up to the light and shook it a bit, and the crystals appeared to form and dissolve with the agitation. I went ahead and poured this curious solution into the overflow tank and brought it up to full. I looked closely at the fluid in the overflow tank afterward and didn't see any of those crystals.
    Today I was doing a maintenance check on my 2021 Gen IV and noticed both the engine coolant overflow tank and the inverter coolant tank were a little low. It has been cooling off here for the past week or so. So I get out my half gallon of SLLC and pour some out into another container, and there are those crystals again. Ambient air temperature today was around 80 F. And when I poured it into the coolant tanks the crystals were gone. Any ideas what is causing this?
  2. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    I've done some reading. Still can't find an exact reference, but I found plenty of chemistry discussions concerning crystallization states of organic acids. The main ingredient in Super Long Life Coolant is something called HOAT. Hybrid Organic Acid Technology. Not my area of expertise, but interesting nonetheless. There is an analog perhaps in meteorology in reference to specific cloud temperature regions conducive to something called dendritic growth. This is a type of ice crystallization at certain temperature and moisture variables leading to rapid crystal formation. Think of winter weather heavy snow. This function still requires a seed or nucleation site to get things started, whereas the crystal formation in this antifreeze is spontaneous and likely due in part to concentration of various chemicals and a lack of contaminants to act as growth seeds. I'm not going to worry about it, unless anyone else has some ideas.
    Mambo Dave and CR94 like this.
  3. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    No ideas, but I'll watch this thread.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,924
    Columbia, SC
    Interesting. I'd have probably put that container to the side and bought a new one. Floaties in anything are outside of my comfort zone. Looking forward to hearing some other experiences on this.
  5. Mendel Leisk
    38,729
    I checked a partially used bottle I've got, purchased and opened two years ago: didn't see anything. Apart from one very sorry fruit fly that hopped in.
    Mambo Dave likes this.
  6. Bender953
    Bender953 Junior Member
    Columbus, OH
    I have a gallon also that has been in the garage for a couple years. I will have to go look. I know when the techs would replace water pumps there would usually be a layer of pink crusties around the edges. I am thinking where the coolant was exposed to air for an extended period of time. Watching this thread also
