"Slow" fuel gauge
Discussion in 'Gen 2 Prius Main Forum' started by xbdude, Apr 30, 2007.
  1. xbdude
    xbdude opticat
    168
    North Central Florida
    My 2006 has 19 K on the odometer, and recently when I fill it with fuel, the gauge does not respond for about 100 miles or so. I usually fill up when the gauge shows about one-half tank-- half the bars. It stays that way for a couple of days, even when the car is shut off and turned on again. Anyone else have this happen?
  2. Mary Snyder
    Mary Snyder New Member
    132
    <div class='quotetop'>QUOTE(xbdude @ Apr 30 2007, 05:51 PM) [snapback]432795[/snapback]</div>
    Yes I filled my tank on April 4 and the gauge still shows 10 bars. I drive it around town about every other day.
    Mary
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(xbdude @ Apr 30 2007, 04:51 PM) [snapback]432795[/snapback]</div>
    I think you are due for a warranty trip to the dealer.
  4. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    Sounds like normal operation to me.
    During the summer, I've seen full bars when I've got 140 miles on a tank, then they'll start to drop. When I get to 2 bars, I fill up. As long as it shows full right after you fill it and doesn't show over 1 bar when you run out, it's considered to be working normally.
    Why do you think they call it a "guess gauge"?
  5. moxiequz
    moxiequz Weirdo Social Outcast
    2,781
    Bay Area, CA
    <div class='quotetop'>QUOTE(Boxster...WRX...Prius? @ May 1 2007, 10:40 AM) [snapback]433339[/snapback]</div>
    I think the problem is when the OP refills the tank the guage does not reset to the "full bars" display. If he fills up when the tank is half empty the display continues to show the "half full" readout until about 100 miles or so after the refueling. I agree with JimN - this definitely sounds like a problem for the dealer to fix.
  6. xbdude
    xbdude opticat
    168
    You are correct, moxiequz-- that's exactly what is happening. I'll give it one more try (fill-ups are soooo far apart!) and if it still doesn't show full, I'll take it to the dealer as I have the extended warranty. Thanks, all!
