slowing down on a rampy road
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tariq87, Mar 1, 2020.
  1. Tariq87
    Tariq87 Member
    87
    28
    jordan
    hi dears
    i need help on this ...
    When I left of the accelerator on a flat road even on a rampy road, I feel like the transmission remains engaged
    And the car slows down quite fast .. the car was not like this before one month
    note : the battery is brand new "almost one year old"
    is it a bad speeding sensor or it`s something else ?
  2. Tariq87
    Tariq87 Member
    87
    28
    jordan
    it`s feels like im driving on B not on D
  3. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    I have no final answer, but let's try to narrow the focus. My first question for you is this: What do you feel when you are driving along and you take your foot off the gas pedal and actually shift into B? If there is no difference, then maybe your car is actually stuck in B all the time when it should be in D. Second question: does the car still accelerate normally? If not, could the brakes be dragging or a wheel bearing failing?
    Mendel Leisk and Raytheeagle like this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    What is a "rampy" road ?
    The transmission is always engaged. It doesn't work like a conventional setup.
    First thing I would do is have the brakes checked to be sure they aren't dragging.
    Soon or immediately. Dragging brakes can overheat and catch fire.
    The regenerative braking "engages" immediately upon releasing the throttle but that action shouldn't be "quite fast".
  5. Mendel Leisk
    38,652
    This is the 12 volt or hybrid battery? Mostly just to clarify, don't really think it's a factor.
  6. Leadfoot J. McCoalroller
    7,135
    6,683
    Pennsylvania
    2018 Prius c
    How's the fuel consumption?
  7. bisco
    49,388
    What happened if you throw her in neutral?
  8. Tariq87
    Tariq87 Member
    87
    28
    jordan
    When i left of my foot the car slowing down quit fast.. it's never shifts to B but its feels like driving on B
  9. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Rampy road it's like going downhill...so if the breaks is too old this will not effect the speed if i accelerate or not as i know maybe im wrong
  10. Tariq87
    Tariq87 Member
    87
    28
    jordan
    It's around 320 km in 20 liters
  11. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Life is back..the car won't slowing down sure because the transmission is not engaged...will it be a bad speeding sensor ?
  12. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Both of them around year and 3 months old "Hybrid and 12 volt"
  13. Mendel Leisk
    38,652
    For info, that's about 6.25 liter/100km, or 37.6 mpg US.
    Seems like what you'd get, driving with too much braking, for whatever reason.
    So this just started happening about a month ago? Did anything happen at that time? One guess: was maintenance done on the brakes, and since then they maybe are dragging??
    Raytheeagle likes this.
  14. Leadfoot J. McCoalroller
    7,135
    6,683
    Pennsylvania
    2018 Prius c
    yeah that's too much fuel burnt, something isn't right.
  15. bisco
    49,388
    if it goes away in neutral, it can't be brakes or bearings or tires. speed sensor would the the traction lite et al.
  16. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Dears im thinking about do a full maintenance which is
    1 change breaks
    2 change spark plugs
    3 change engine air filter
    4 clear egr and egr coolent
    5 clean throttle body
    6 clean MAF sensor
    7 check and clean speed sensors
  17. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    Full maintenance list w/o an oil change :eek:
    Tariq87 likes this.
  18. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Dears..after full maintenance the pervious semptoms gone away. .the car now runs smoothly with no issues..
  19. bisco
    49,388
    darling, how do you check and clean the speed sensors?
  20. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    This thread has become very sappy :love:.
