Sluggish acceleration during Hybrid Battery in Charging Stage?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tekken, Oct 24, 2021.
  1. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    Hello,
    When Hybrid Battery drop to 2 Bars, ICE kick in to charge Hybrid Battery. During this stage of charging, the Prius sluggish acceleration or lack of power, is it normal ?? If not, what may cause this sluggish acceleration.
  2. rjparker
    rjparker Tu Humilde Sirviente
    8,233
    4,885
    Texas Hill Country
    If the hv battery is really low it may not be contributing much to your acceleration. In addition more of the engine's hp may be diverted to the battery. When the hv battery is newer it has more capacity even at low bars.
    Maarten28 likes this.
  3. Tekken
    Tekken Member
    257
    77
    I believe, i didn't need any Hybrid Battery to contribute my acceleration at the Costco parking lot and looking for parking space with Parking lot speed limit between 5-20 mph. The acceleration still sluggish
  4. rjparker
    8,233
    4,885
    Texas Hill Country
    That is when you normally use the hv battery the most. An Atkinson cycle engine has very little torque at low speeds. Your battery is getting old.
  5. Tekken
    Tekken Member
    257
    77
    Once ICE kick in, it doesn't need Hybrid Battery.. Unless, I flooring gas pedal which it was not necessary during in parking lot drive.
  6. rjparker
    8,233
    4,885
    Texas Hill Country
    Actually the high voltage normally available from the hybrid battery is used all the time especially at low speeds. At minimum it has to run the electric motors to maintain sync with the engine. At low speed it runs in parallel with the engine. When the hv battery can not contribute due to low capacity, one electric motor is trying to charge the battery while the second is receiving electricity from the system. I promise you that low hv battery capacity dramatically reduces power to the wheels even with the engine on.
    There is an easy test: When the battery has a high charge, do your parking lot test. Acceleration will be normal, at least until the charge depletes.
    #6 rjparker, Oct 25, 2021
  7. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    That is not true. I notice a big difference in normal acceleration with low battery and normal battery. The ICE will rev noticably more when the HV battery is low.
  8. johnHRP
    johnHRP Active Member
    417
    133
    tally, fl
    It depends on how much your throttle is. At close to full throttle, it will be all to the wheel but at low and partial throttle, it depends on battery charge level. Especially the torque feel when the 2nd generator does not contribute much because of low battery level.
