Sluggish Fuel Gauge/instantaneous readout
Discussion in 'Gen 2 Prius Main Forum' started by shelterdog, Nov 5, 2007.
  1. shelterdog
    shelterdog Junior Member
    On my 2007 Prius, I've noticed the readout of the MPG seems extremely sluggish. I previously owned a 2004 Prius, and on the way to work (mostly downhill) I got about 7-10 mpg more than on the uphill drive home. Likewise, on the way to our vacation home in the mountains (uphill), I got about 10 mpg less than driving back (downhill). No surprise.
    On my 2007 Prius, driving exactly the same routes, the fluctuation is FAR less--only 0-2 mpg more during the downhill segment than the uphill one.
    By itself, this might have been just a curiousity, but last weekend, I was low on gas (down to two bars on the fuel gauge), and added about 3 gallons from a 5-gallon gas can. After doing so, the fuel gauge remained on 2 bars, and stayed there while I drove 100 miles to the gas station.
    Is this the way the system is supposed to work?
  2. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I can't speak to the instantaneous display issue, but I'm fairly certain that the fuel gauge doesn't reset unless you add 3+ gallons. You might just not have hit that threshold for the gauge to reset.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Ichabod's correct about the fuel level reset.
    The '06+ MY prius consumption screen MPG display has changed since the '04/'05 MY. It is now a cumulative/lifetime readout unless you manually touch the 'reset' button on that display. The MPG doesn't reset at the time of fill up as it does on the '04/'05. Thus the further you drive between hitting that reset the less fluctuation you'll see on that display.
  4. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    <div class='quotetop'>QUOTE(Shelterdog @ Nov 5 2007, 08:49 PM) [snapback]535229[/snapback]</div>
    5helterdog,
    Check out the discussion on: http://www.priusonline.com/viewtopic.php?t=11455
