Small gap in fender area?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sosarahsays, Feb 6, 2014.
  1. sosarahsays
    sosarahsays Member
    117
    37
    PNW
    I noticed the seam between the body and the bumper/fender part on my Prius was gaping ever so slightly today. It looks like there are a few light scratches, so maybe someone lightly bumped me? I tried pushing it in and up in case a clip wasn't catching, but I can't get it to completely close. Any ideas, Prius chatters? I know it's a minute thing, but now that I've noticed, it bothers me.
  2. JC91006
    16,482
    8,399
    I would recommend you stop looking at it, it'll just bother you more. Someone might have bumped you but I can't tell by the pictures. All the clips look to be in place. Could also be your imagination. .....
    SM-N900P ?
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    That would bother me too. :(
    You could try removing the bumper cover and check the clips.
    SCH-I535
  4. orenji
    orenji Senior Member
    5,884
    3,486
    I see it and that would bother me too, have a mobile bumper guy come by and look at, should be a simple fix.
  5. sosarahsays
    sosarahsays Member
    117
    37
    PNW
    Is that a tough operation? I don't have a garage or anything. Is there a screw in that area that might just need to be tightened? I looked around but didn't see anything obvious.
    I didn't even know mobile bumper repair was a thing! I will look to see if we have any here in DC.
    Both of these things failing, might just take it to an auto body shop and hope it's not too $$$$. It's really probably mostly noticeable to me, but I like things perfect and now I know it's there. :(
  6. orenji
    5,884
    3,486
    Or road trip to Cali, and have it repaired by a Mobile Bumper dude! :LOL:
    DadofHedgehog and sosarahsays like this.
  7. JC91006
    16,482
    8,399
    There is only 1 bolt that holds the bumper, it's at the end of the bumper, both sides are the same. Rest of them are like bumper clips, which looks to be in place. Not sure what else you can do.
    You can look at some YouTube videos. Look for headlight removal videos, many take off the bumper.
    SM-N900P ?
  8. sosarahsays
    sosarahsays Member
    117
    37
    PNW
    So, I was just watching this video for a Gen II, but maybe the Gen III is similar and I can just get a new bumper cover retainer for the front? Hmm... [off to research some more]
    ou812 likes this.
  9. El Dobro
    El Dobro A Member
    6,978
    3,213
    Just loosen the bolt and push the bumper cover back in place.
  10. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    You can check Washington Checkbook.com or possibly Angie's List for repair shops in our area that may be good for smaller stuff. If you find one, let me know.
    Washington Consumers' CHECKBOOK
    sosarahsays likes this.
  11. sosarahsays
    sosarahsays Member
    117
    37
    PNW
    Which bolt? The one in the wheel well? I'd love it if I could just loosen and re-tighten it back into place. You think I can do it with a hand screwdriver? I don't have a power one...
  12. sosarahsays
    sosarahsays Member
    117
    37
    PNW
    Guessing this is the screw thing (technical term) in the wheel well?
  13. El Dobro
    El Dobro A Member
    6,978
    3,213
    Yep, that's the one. It's a bolt that takes a 10mm socket.
  14. sosarahsays
    sosarahsays Member
    117
    37
    PNW
    Cool, so you think I should just loosen it, push it back into place, and tighten it up?
    This might be the cheapest DIY ever.
  15. sosarahsays
    sosarahsays Member
    117
    37
    PNW
    ETA: When I bought the car, there was some road rash/cube scrapeage on the bumper cover that the stealership repaired as part of the sale. I am wondering if they just didn't re-install the bumper back exactly right and I am just noticing now...
  16. El Dobro
    El Dobro A Member
    6,978
    3,213
    Mess with it until it looks better. The screw may even be too tight, which will push the bumper cover out.
  17. emily's prius c
    emily's prius c New Member
    MA
    I'm having a similar issue--clipped a snowbank this winter and now the seam of the fender is popped out on one side. How can you tell by looking if it is still in the clips? Do I have to unbolt it too? I didn't see the bolt in the wheel well. Do you know approx where it is?
  18. emily's prius c
    MA
    here is what it looks like--when i look at the other side, there seems to be a piece on the inside that catches the eyelet-- i dont see a piece when i gently pull the fender back ??
