Smaller Key and/or FOB
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Rant2112, Mar 17, 2016.
  1. Rant2112
    Rant2112 New Member
    Austin, TX
    Three Touring
    Is there a smaller key available that can start the car? The Prius is my wife's car and I don't want to carry around the giant fob for the occasional times that I need it.
  2. Caniac
    Caniac Active Member
    232
    164
    Happy Valley
    I use valet key rings and have one for each different car. When I am going to drive another car I just change out the key section. upload_2016-3-17_14-25-35.jpeg
    SpecialK and krmcg like this.
  3. JC91006
    16,474
    8,393
    I would just leave the key fob at home unless you're actually going to drive the car.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I do the same.
  5. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    I don't even put my car key on my key ring. I haven't for quite a few years.
  6. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Some people put that awkward lump on a ring with keys?
  7. bisco
    49,371
    yes, there is a lexus credit card key that can be programmed for the prius. you can keep it in your wallet.
    glennonrp likes this.
  8. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    It's easy enough to just take the circuit board out of the plastic keyfob case. Then fabricate a smaller protective enclosure. A really simple hack would be to make a sandwich of several obsolete credit cards around the circuit board. Be sure to allow the switches to remain unpressed. Wrap the whole thing in tape. Take a picture of your craftsmanship & post it for us to see...
    krmcg likes this.
  9. ucla107
    ucla107 Member
    98
    107
    Four Touring
    OHH! Do you have a link or more info on that?
  10. Caniac
    232
    164
    Happy Valley
  11. RobH
    RobH Senior Member
    2,369
    979
    70
    Beware that most Prius use a 14ACX type keyfob. This 14AAB unit will only work if your (rare) vehicle has a 14AAB keyfob.
  12. randomwalk101
    randomwalk101 DYI'er
    532
    269
    texas
    2016 uses the 14FBC I believe.
  13. bisco
    49,371
    larger and more powerful?
  14. RobH
    RobH Senior Member
    2,369
    979
    70
    Just different. You wouldn't want the supply of used fobs out there intrude on the new sales now would you...
    Actually, the new one is probably more integrated. Fewer discrete parts, and cheaper to manufacture.
    Maybe someone with a 2016 could pop theirs open and post a picture.
  15. krmcg
    2,592
    2,390
    Whittier, CA
  16. slinke1
    slinke1 Junior Member
    2016 Prius v wagon
    Sounds like a good application for Sugru!
