smart key battery change?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by furtceli, Feb 14, 2014.
  1. furtceli
    furtceli New Member
    does anyone know how to take out and change the battery for 2014 Prius II smart key?
    Thanks so much for the info!!!!!
  2. Shaka808
    Shaka808 Junior Member
    YouTube video on changing Prius smart key:
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Shaka808, that video is for the 2nd Gen Prius key FOB.
    furtceli, here is the video for the 3rd Gen Prius key FOB.
  4. Shaka808
    Thanks NutzAboutBolts for the correction, I actually subscribe to your channel on YouTube and watched all of your Prius service videos, quality stuff and very helpful, thanks for taking the time to post it.
  5. NutzAboutBolts
    1,476
    1,552
    Bay Area
    Not a problem :) thanks for subscribing! more will come when the time is needed for sure.
  6. furtceli
    furtceli New Member
    thanks everyone!!!!!
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Its in the owners manual too.
  8. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    My curiosity question is:
    With a brand new car (2014), not more than 6 months old....right?....
    why would you NEED to change the battery already ??
  9. bisco
    49,379
    was wondering the same thing. be prepared?:)
  10. edthefox5
    10,096
    4,804
    Clearwater, Florida
    How long do you think the batteries have sat in the new fob? And they won't be as charged up to begin with as say a brand new quality cell.
  11. Easy Rider
    982
    210
    N. Central Florida
    While that sounds like a logical assumption, you don't know how OLD those fresh quality cells are either. :)
    The system will warn you when the battery is getting low.
    The book says they should last at least one year, maybe two.
  12. furtceli
    furtceli New Member
    Yes, I was just curious and would like to be prepared;). I was also wondering since the new car came with two smart keys, would it save the battery if I simply take it out of the one I am not using and put it back in when needed. Would that in anyway damage the key (without battery in it)? Has anyone tried it?
  13. Easy Rider
    982
    210
    N. Central Florida
    In my opinion, you are worrying about this MUCH too much.
    The batteries are cheap. Every time you pry open the case there is potential for damage.
    I think I read that an unused FOB "goes to sleep" if kept away from the car so just leaving it in the house should
    extend it's battery life a LOT ; there is a procedure for "waking it up" after extended periods of non-use.
    There also is a "manual" procedure for starting the car when the FOB battery is dead.
    Don't let OCD ruin your life.
    If you haven't already, you should read your owners manual.
    It has a LOT of good stuff in there.
  14. furtceli
    furtceli New Member
    great info, easy rider, thanks!!!! me a worrier :oops:
  15. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Try taking the battery in and out a few times.
  16. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Do you have to re-learn or re-program anything after changing the battery?
  17. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Nope. No programing.
    But its best to keep the fob a distance away from the car as it will communicate with the fob within distance for quite a while then time out. If you can actuate the fob its within communicating distance. Remember there's multiple antenna's in the car and the system will do all it can do to initiate com and keep com to the fob.
  18. mediahound
    903
    155
    Thanks. Yeah, I've learned not to store the extra key by the car.
    edthefox5 likes this.
