smart key battery drain
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pabeth, Apr 24, 2012.
  1. pabeth
    pabeth New Member
    PA
    My key died like 2 weeks ago I replaced the battery and it was dead again 1 day later, toyota told me it was too close to the car but I have kept the key in the same spot for over a year and a half plus the other key right next to it and it works fine. I have replaced the battery 2 more times and each time its dead within 48 hours. is there a possible short somewhere and where would i look? any ideas?
  2. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Over the weekend (48hrs) remove the car battery (+) lead and see if the fob battery dies again.
    If not then the car is the cause, if yes there is a short in the fob draining the battery and the car has nothing to do with it.
    my2cents.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Is there a button stuck on the fob? Do you have the same problem with the spare fob?
  4. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    I agree this is something with the fob not the car ... no way ...
  5. bisco
    51,141
    if one fob is fine, it must be a bad fob. i vote for the stuck button mentioned above by fire.
  6. markabele
    5,084
    1,782
    Nebraska
    Is it smart to store the key are certain distance away from the car?
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Yes. When nearby, the key and fob interact with a query and response: "You there?" "Yes, I'm here." It goes on and on, draining the fob battery and the 12V battery on the Prius.
    Tom
  8. RobH
    RobH Senior Member
    2,374
    987
    70
    Sunnyvale, California
    This even happens with a fob for another car. I have a radio that can tune in the 134.5 Khz car-to-fob signal. With the correct fob, the slow pulse changes to a chatter when the fob gets within about 3 feet of the car. The led on the fob also lights up when this happens. With a fob for another Prius, there is a different chatter, and the fob led doesn't light. But both the car and the fob are using their batteries...
  9. markabele
    5,084
    1,782
    Nebraska
    This is something they should have put in the owner's manual.
  10. bisco
    51,141
    thought they did.
  11. qbee42
    18,058
    3,076
    Northern Michigan
    They do, but you can't force people to read it.
    Tom
  12. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    ^^^ :D Very evident when you have the JDM mirrors with puddle lights. The interior dome light lights up too when the key fob is within range = drainage as you stated.
  13. markabele
    5,084
    1,782
    Nebraska
    I actually did read every word of the manual and no where did it state this. Please tell me a page number if you find it.
  14. er86
    er86 Junior Member
    42
    Austin, TX USA
    I am still reading the manuals since I just picked up my Prius last week, but would welcome the page number as I live in a condo with parking in front of the unit so I am very close.
  15. firepa63
    1,761
    208
    It is in the manual...!
  16. markabele
    5,084
    1,782
    Nebraska
    You've read the 2012 manual? Because I have, and I have not found where it says that. If you know better than I do please enlighten me as to a page number. Thanks.
  17. qbee42
    18,058
    3,076
    Northern Michigan
    The manual has been rewritten for 2012, talking around the point instead of explicitly stating it:
    Page 75:
    Page 76:
    Tom
  18. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    I would challenge anyone :fencing: (Toyota designers, engineers, manual writers and executives included) carrying their key fob in their pocket, who also regularly carries a cellular phone, to keep their cellular phone 3 feet from their electronic key fob. Same goes for people who work at a personal computer all day.
  19. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    Ok, I am having the SAME problem with my FOB Key, and this is my 2nd Prius. I had a 2007 prior to this. NEVER did I replace the battery in my FOB Key. My 2011 Prius is parked in the SAME garage, same place, my FOB key is in the SAME PLACE inside the house when I'm not driving the car as my 2007 was. WTH is going on???
    I'm really frustrated about this. My first key died after 2 months of use. I replaced the FOB battery with an Energizer extended life lithium battery, about 3 weeks ago. Go to start the car this morning and ... NO KEY DETECTED. The key is dead!!!
    WTH????
  20. WE0H
    WE0H Senior Member
    3,247
    528
    Maybe put the spare FOB in an empty Altoids tin so the car wouldn't be able to communicate with it or it'd be harder for it to see it in the house? Just make sure someone doesn't throw the supposedly empty tin in the recycle container :eek:
    Mike
