Smart Key Disable Switch
Discussion in 'Gen 2 Prius Main Forum' started by UK_Pete, May 26, 2015.
  1. UK_Pete
    UK_Pete New Member
    London, UK
    I have a RHD 2006 Prius. My Smart switch stopped working suddenly - I could no longer use it to lock/unlock the doors. I replaced the battery, and the status light on the fob does light red with every press.
    I checked the switch under the steering column, but I when I press the button, it doesn't stay clicked in (if that makes sense). I removed the switch, and connected it to a multimeter. It reads 0ohms when I am actually pressing the switch, but reads open as soon as I stop pressing. Is this the expected behavior?
    We bought the car used, and it only came with a single fob, so I don't have another fob to test.
    Any thoughts on what else there is to test?
    Cheers,
    Pete
  2. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Hi Pete. Welcome to PC.
    The UK key fob is somewhat different to the US SKS system smart fob. When you say you removed the switch I assume this is the one in the fob can you confirm this? If that is the case the operation shown by the meter is correct.
    You could try the chicken dance method of re programming your fob, but I doubt this is the problem. (Search this in the box at the top of the page.)
    I suggest you buy a "Mini VCI" from Ebay (about £15) and use it with an old laptop to look at the car programming for the fob. The car is programmed to recognize the fob "not the other way round".
    The VCI is basically the same level diagnostics tool that the dealer uses for all sorts of tasks including fault code reading for which they will happily charge you £100.
    You do need to buy another fob. If you loose the one you have it will be very expensive to get the car to be re coded to accept a new fob. With an existing fob a new fob can be made to be recognized with the VCI.
    There is a "door fuse 25 amp" under the dash above your right foot. "Worth checking."
    If I can help more just ask.
    John (Britprius)
    #2 Britprius, May 26, 2015
    51,141
    also, check your 12 volt health.
  4. UK_Pete
    UK_Pete New Member
    London, UK
    Thanks for the replies thus far.
    I am referring to the smart key disable switch located under the steering column. I find it strange that I cannot tell the difference between on and off on the switch. I am wondering if the switch is in fact defective.
    I did read about the chicken dance, but I believe that I need a working remote to do that.
    I will look into the MiniVCI and will definitely add a replacement key fob.
    Thanks, I did replace the 12V battery about 5 months ago after I had some trouble starting the car.
  5. Britprius
    5,194
    1,918
    Pete in the UK version it does not disable entry system it disables the interior alarm.
    John
  6. bisco
    51,141
    pete, are you saying that the car won't power up? or you can't unlock the doors? or you have to put your fob in the slot to power up?
  7. Britprius
    5,194
    1,918
    All UK gen2's you have to put the fob in the slot. We did not get SKS this side of the pond. Something I would add to my car if I could get the parts here, but they are not available.
    John.
  8. UK_Pete
    UK_Pete New Member
    London, UK
    Car powers up fine - I just have to remove the physical key from the fob to lock and unlock the doors. I have replaced the battery in the fob, but I still cannot use it to lock or unlock. Apologies if I wasn't clear in the beginning.
  9. JC91006
    16,672
    8,518
    did you check other doors for sks function? Also check if there are any stuck buttons on your fob, make sure ALL the buttons "click" when you press them......
  10. bisco
    51,141
    could be your lock motor, does it work from the inside switch?
  11. UK_Pete
    UK_Pete New Member
    London, UK
    Yes, it works from the inside.
    Any idea where the receiver for the remote is located?
  12. bisco
    51,141
    i think the center console, but not positive.
  13. jjmerp
    jjmerp Junior Member
    51
    22
    Ohio
    Both front door handles center console and one rear hatch.The attachment shows locations.
  14. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    All this information is applicable to the SKS function, which it has been established the UK Gen II models DO NOT have. If people could read threads before jumping in, it would help ensure you don't waste people's time with information that is not applicable.
    I say this in the nicest possible way. :D
  15. bisco
    51,141
    but it was ukpetes first post, saying his smart switch stopped working suddenly, that led to the incorrect replies.
  16. dolj
    dolj Senior Member
    8,209
    4,180
    True, but Britprius corrected the error in post #5:
    and to be more precise the switch disables the interior movement sensor. It's purpose is so you can leave e. g. a dog in the car and lock it and not have the dog set off the alarm when it moves around the cabin. (y)
    #16 dolj, Jun 2, 2015
    Britprius likes this.
  17. bisco
    51,141
    correct, but then ukpete asked where the receiver was.
  18. dolj
    dolj Senior Member
    8,209
    4,180
    To which the replies were the location of the SKS receivers, so not relevant to cars w/o SKS.
  19. bisco
    51,141
    well,there has to be a receiver somewhere.
  20. dolj
    dolj Senior Member
    8,209
    4,180
    This is true.
