Smart key disruption
Discussion in 'Gen 2 Prius Main Forum' started by Kablooie, May 28, 2005.
  1. Kablooie
    Kablooie Member
    273
    La Canada
    I tried opening my locked car the other day but it wouldn't respond. The smart key was in my pocket as usual.
    I took off my headphones and inspected the fob. It seemed OK. I tried pressing the button and the door unlocked right away.
    I relocked the door and put the fob back in my pocket and tried again. No luck. It wouldn't unlock.
    I was starting to get concerned when I realized that my ipod was in the same pocket. I took it out and the fob unlocked th door just fine. I put the ipod back in and the fob wouldn't work.
    Moral: Don't let your fob become to close to your ipod or they may decide to ignore you.
  2. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    Considering that the Prius SKS, keyfob, and the Ipod both conform to FCC part 15; they will both accept the RF radiation from each other. Thus, canceling each other out.
    It's more likely that the transmit frequency of the keyfob is about the same as one of the processors in the Ipod. There was just too much noise in the 'band' to broadcast. Same idea behind signal jamming.
    The keyfob transmits at 312.5MHz and has bandwidth of 780.375KHz.
    Tokai Rika designed the Prius keyfob in 2003.
  3. Blue
    Blue New Member
    46
    Alexandria, VA
    Cell phones can cause a similar problem. For example, I am unable to lock the doors using the fob or the handle button if I leave my cell in the Prius. If I lock the doors using the power lock located inside the door, then close the door, the Prius will unlock the doors automatically.
    I suppose it could be considered as a gentle reminder not to forget your cell.
  4. oly_57mpg
    360
    Humm... There's something that's not right about that. Who is your wireless service provider? Verizon? They're the only provider that has phones that emit that much RF radiation.
    Not all phones cause the problem you describe.
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    It happens to my wife and her cell in her purse and if it's between the fob and car, better get her a hammer to break the window cause she isn't getting in.
  6. tag
    tag Senior Member
    2,526
    Chicago
    Yep........something's not right BUT, whatever it is, it certainly doesn't have anything to do with Verizon.
    I have a V710 (SAR at ear = 1.40) and have had an extremely difficult time reproducing the one SKS interference incident I encountered. I have placed the fob and phone in direct contact with each other, in differing positions, and the car still powers up.
    As an aside, FWIW, both Cingular and Verizon have the Treo 650 and both have the same SAR despite the fact that one is GSM and the other CDMA.
  7. oly_57mpg
    360
    Yeah, you're probably right. But I've been witness to many RF problems associated with Verizon...
  8. Blue
    Blue New Member
    46
    Alexandria, VA
    It's actually Cingular, with a Sony Ericsson T637 Bluetooth phone.
  9. brandon
    brandon Member
    771
    Manhattan, KS
    Power lines can cause similar problems. After washing my Driftwood, I parked next to a power transformer and began to dry it off. The vehicle occasionally locked itself (did not unlock itself, though). I moved it away from the transformer, and the odd behavior disappeared.
  10. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(brandon\";p=\"93718)</div>
    the car will do that if you have the fob in your pocket and the car is still wet and you are drying it near the door handles. Had this happen lots of times. Now I just throw the fob on the seat and dry the car.
  11. xevious
    xevious New Member
    187
    Oregon
    Does anyone know what frequency the SKS uses? My guess would be the 902-928MHz ISM (US) band, which is very close to two cell phone bands (930MHz and 1800MHz). Not every cell phone uses these bands; there are several others available in the US.
    I would guess that the very weak SKS signal (1-2dBm) is experiencing interference from a nearby stronger (~5-23dBm, depending on mode) cell phone signal.
    Or, the cell phone's signal could be effectively jamming the SKS fob's receiver and confusing the fob's MCU. Much more likely scenario.
    Keep them in different pockets and see what happens.
  12. prius04
    prius04 New Member
    1,161
    NorthEast USA
    Has anyone considered the possibility that the reason the FOB didn't work with the iPod was because the FOB was too busy listening to the music?
    Rather than putting the devices in different pockets, how about trying show tunes, then rap, then c&w, then heavy metal then throw in a podcast of Rush L then Al F.
  13. geckoboi78
    geckoboi78 New Member
    53
    Va Beach, VA
    <div class='quotetop'>QUOTE(oly_57mpg\";p=\"93659)</div>
    Actually I have the same exact problem and I have sprint. They also address this in the manual and forewarn you that cell phones and other devices can interfere with the key fob if kept together in the same place such a a purse or pocket.
  14. oly_57mpg
    360
    xevious -
    Please read my post above.
    Nope. Not even.
