Smart Key door handles
Discussion in 'Gen 3 Prius Accessories and Modifications' started by fromdirt, Jul 22, 2013.
  1. fromdirt
    fromdirt Junior Member
    Can my 2013 Prius II currently equipped with driver door only smart key access be :
    a. Programmed to unlock / lock all doors upon touching driver door handle?
    b. Can a OEM "Smart Key" front passenger door handle be installed & programed to function as if factory install?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    a: Yes, it's in your manual. Watch this video, it's at the 1:34 mark.
    b: You can install one, but it needs to be wired properly. See this thread.
    fromdirt likes this.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    I would recommend not programming all doors to unlock upon touching driver door handle for safety reason. It's not really desirable if you're in a dangerous area. Instead, you should have the dealer program the fob to open all doors at once and can use the fob whenever you're carrying passengers.
