Smart Key / Door Unlocking questions
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pasaman, Jun 4, 2014.
  1. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    On my 2014 base PiP when I open the drivers side door none of the others unlock. When I open the passenger side door all doors unlock. How can I set it up so all doors unlock when the front drivers side door is opened?
  2. blkpriusgirl
    blkpriusgirl Junior Member
    29
    San Francisco, CA
    2014 Prius Plug-in
    In the manual it rolls you how to program your key to open all doors.
  3. Pasaman
    289
    115
    Southern California
    Guess I should have checked there first...haha
    52,370
    it's a bit complicated, but i got it after a few tries.(n)
  5. KV1955
    KV1955 Member
    49
    36
    Manassas, VA
    2014 Prius Plug-in
    ok.... so if I enter the car through the driver's door, so only that door unlocks, will the others unlock if someone approaches and touches the passenger door handle? Does the car know that the key is inside? And can the key be locked into the car? (Sorry for all the questions...still haven't figured out all this high-tech stuff)
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Read the manual, it's all explained in there. ;)
    If you try to lock the car with a fob inside it will beep at you and won't lock.
    SCH-I535
  7. bisco
    52,370
    if you're in the drivers seat with the fob in your pocket, someone touching the passenger door handle is too far away. i had to reprogram so my wife could get in without me pushing the unlock button on the door. i left her hycam with driver door only so someone can't jump in when she's alone.
