smart key malfunction when locking car
Discussion in 'Gen 2 Prius Main Forum' started by terry2336, Nov 29, 2009.
  1. terry2336
    terry2336 Junior Member
    17
    Maine
    when I try to lock my 2005 pkg 4 Prius by pushing the button on the outside I get a long beep from under the hood and nothing happens. It locks fine by pushing the lock button on the key and starts the car fine. anyone know whats wrong
  2. macmaster05
    macmaster05 Senor Member
    4,050
    729
    I have the same problem sometimes. I think it's only happened to me twice though.
    I remember hearing from these chats that you have to unlock the car the same way you lock the car. For example, if you press the key fob to lock it then when you return to the car you have to press the Unlock on the FOB again.
    Maybe that has something to do with it? Maybe when it happened, you previously had unlocked the car with the FOB, thats why pressing the button on the handle to lock it, didn't work. I wish I knew...
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Typically the long beep means that the other fob is still inside the car. The SKS keeps you from locking your fob inside. You can, however, lock a fob inside using the button on another fob.
    Tom
  4. macmaster05
    4,050
    729
    Not exactly true. While this happens, the couple times that I got the long beep, my second FOB was definitely not in the car...
    I keep the spare inside my house at all times.
  5. qbee42
    18,058
    3,074
    Northern Michigan
    This is exactly true. Typically it means the extra fob is in the car. There may be other reasons, however.
    Tom
  6. Patrick Wong
    18,200
    6,479
    Sometimes you'll get a long beep just because the car did not register the presence of the Smart fob outside the car. In that case, if you press the black square button again, usually the car will lock without further incident.
  7. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Also, make sure your fingers are not wrapped around the door handle when pressing the black button.
  8. terry2336
    17
    Maine
    Problem solved! Although she swore it was in her purse my wife had hidden her key in the cupholder. alls fine.
  9. qbee42
    18,058
    3,074
    Northern Michigan
    It's amazing how often this happens. :)
    Tom
