Smart Key not Smart anymore
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kasia, Sep 6, 2015.
  1. Kasia
    Kasia Junior Member
    Decatur, GA
    Hi all (newbie here),
    I've combed through Prius Chat and haven't found any thread with this exact problem/issue. I attempted to add a used "eBay" fob to my 2006 Prius. This did not work. What happened afterwards is that my SmartKey is no longer smart. The car will start if I have the key in the slot. The sensor no longer works. Any ideas on how to have my fob be smart again?
    2nd issue: Any way to program the eBay fob's. I've heard Techstream and codes from online sources. I see Techsteam software on eBay for ~$15 BUT some state that they will not program keys. Anybody have had any luck programming hteir fobs for cheap??
    Thank you!!!!!
    49,741
    welcome! there are a few threads here, with many posts and advice. i think the main thing is, you need a new fob. try searching key words like 'key fob programming' and 'chicken dance', etc.
  3. Kasia
    Kasia Junior Member
    Decatur, GA
    sigh.. thanks Bisco.. I don't understand why I would need a new fob. It was working just fine until I did the chicken dance with it. I have searched priuschat and seems like noone has posted my specific issue.
    49,741
    sorry, i didn't mean your old fob, i meant trying to program another one. i don't think you can program a used one. your old one probably just needs reprogramming.
  5. Kasia
    Kasia Junior Member
    Decatur, GA
    Any suggestions on how to reprogram the key myself??
  6. bisco
    49,741
    yes, read through the threads i mentioned above. it's too complicated for someone to remember.
  7. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    You learned the old addage (penny wise, pound foolish), the hard way about used Toyota SKS fobs.
    You can add a used sks fob to your sks prius, but this used fob will lack sks functionality, as you learned. Not having an sks fob work properly, sure kills the convenience of that feature, esp since your car is an sks model Prius.
    Had you purchased a new SKS fob from a local Toyota dealer or an online Toyota dealer (just under $100), you could have done the reprogramming yourself and maintain sks functionality.
    To regain sks functionality for this used sks fob you have two choices, but only one given your lack of knowledge and likely limited DIY capability.
    1) Price shop local dealers for reseeding the current sks fobs in your posession; $200 range is what I have heard. This procesure will clear all sks fobs from the prius sks ecus; Prius only has room for four. The two sks fobs on hand will be added one at a time to the prius sks ecu, leaving you room for two more to be added down the road. The nice thing about the maser reset is the lost sks fobs will no longer work on your car. You can push the dealers for discounts (AAA, Costco, etc); this procedure is easy for them and not laborous despite the BS they tell you.
    2) Acquire Techstream, a spare 32bit Windows based laptop (XP or 7), and pay for a master reset procesure from someone in Europ selling this service. I have read of one person doing this on PriusChat; too sketchy for me. You already got burned once, cheaping out.
