Smart Key(s) not being recognized
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusFruit, Jul 20, 2018.
  1. PriusFruit
    PriusFruit Member
    97
    102
    San Francisco
    Yesterday, I had the front windshield of the 2007 Prius I drive tinted. The car worked fine when I picked up the car from the shop, however this morning I wasn't able to enter or start the car without using the manual key and inserting the fob into the slot.
    I read through multiple posts on this topic and so far I've tried the following:
    • replaced fob battery
    • checked 12V battery voltage through dashboard (11.9 - 12.1)
    • checked 'Key' switch to make sure it is out (on)
    • checked for any stuck buttons on the fobs
    • tried using 2nd fob key (to no avail)
    Unfortunately, none of this seemed to help.
    I'm wondering if the tint job has anything to do with this. Possibly fluid found its way to some components during the installation process. I'm not sure.
    I'm hoping others have some advice for me.
    Thank you
    51,154
    you need a new 12v. or at least charge it up and monitor for a few days. should be at least 12.4 volts.
    generally speaking, tint and other service shops will leave the doors open and other things on with the car in acc mode, running down the 12v.
  3. JC91006
    16,673
    8,518
    There's a SKS button under the steering wheel, by your knee area. Press that and see if anything changes.
    SFO and Raytheeagle like this.
  4. PriusFruit
    PriusFruit Member
    97
    102
    San Francisco
    @bisco - everything started working again towards the end of the day on Friday. And so far things seem to be normal.
    Do you think a replacement battery is still needed?
  5. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    You got a multimeter :whistle:?
    My bet is they had the doors open and ran the battery low:(.
    Take your Prius for a nice long run (say an hour) before traffic gets bad;).
    I’ll be doing a similar thing to our RX450h Friday :).
    What % tint did you go with?
    PriusFruit and bisco like this.
  6. bisco
    51,154
    depending on the age of the battery, it would be well to monitor it. otherwise, just wait to see if it dies again or replace it prophylactically.
    Raytheeagle likes this.
  7. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Always keep your advanced guard up(y).
  8. bisco
    51,154
    exactly
  9. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    The Greeks were onto something there:).
  10. PriusFruit
    PriusFruit Member
    97
    102
    San Francisco
    I think this is right on the money!
    I went with 70% Lumar tint for the front windshield.
    Thanks guys! I’ll keep an eye on it.
  11. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Trying to decide between 50 and 70%. You got a pic :whistle:?
    I’ll be going with Huper Optik ceramic :).
    Good luck and keep us posted (y).
  12. PriusFruit
    PriusFruit Member
    97
    102
    San Francisco
    I’m out of town at the moment and without my car.
    Ceramic is a good choice, more effective at blocking out heat.
    If you want more of a tint on the front windshield, then I would go with the 50%.
    The 70% tint with Lumar is faintly noticeable.
