smart key signal weak
Discussion in 'Gen 2 Prius Main Forum' started by nakago12, Jul 1, 2011.
  1. nakago12
    nakago12 New Member
    my 2005 prius just passed 100K miles, recently i noticed the smart key signal is weaker and weaker. I.E. he car some times does not "feel" the key when it's in a thin bag, or pockets. or cup holder. while it definitely did a few years ago.
    I switched the battery, (just generic ones) from a local drug store, and it didn't seem to help.
    do i need new "OFFICIAL" battery ? or just new smart key altogether?
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    there is no official battery. the generic 2032 from the drug store is the only option.
    the only reason the prius has a special battery (12v) is because of the way everything vents. maybe something about the rate of charge but i don't remember... just going off physical things.
    i've been noticing this myself too. i wondered if it was the door static sensors but there seems to always be a difference with it near change or being too tangled in the keys in my pocket, even a credit card being too close. It was only a problem with the phone previously.
    i wondered about the static sensors since the hatch always works better than the door. the hatch errors 1 out of 60 times or so while the door will error 1 out of 10 times or so.
    with the hatch, there are tricks... it's a button under a static pad (i think)... so you can slightly touch the rubber (you'll feel it slightly indent) and it will unlock the car as you walk around. i used to only use 1 finger on the door when now i use at least 3...
    sometimes less grip and more of a swipe (thinking more sensor coverage) works better for me.
    i have all sorts of little methods for my madness... i test little things like this all the time.
    they have plastic lens cleaner... it's a polish.. i was thinking of using some on a door "sensor" (inner handle plastic). i would do test beforehand to see what changes if anything.
