Smart Key won't work even with new battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by turbo5spd-prius, Jun 29, 2024 at 8:23 PM.
  1. turbo5spd-prius
    turbo5spd-prius Junior Member
    52
    United States
    My car wouldn't start unless I put the fob in the dash insert. I replaced the battery but it still won't work without being in the dash.
    The old cell, less than a year old is 3.1V. The new is 3.3V
    What might I be missing?
    49,357
    does the fob light come on when you press a button?
    how is the 12v health?
  3. turbo5spd-prius
    52
    United States
    The 12V battery seems fine at 12.6V measured under hood.
    #3 turbo5spd-prius, Jun 29, 2024 at 8:36 PM
  4. turbo5spd-prius
    52
    United States
    The light does flash on the fob. I measured 12.6V under the hood between the jumper terminal and chassis.
    I guess I'll add that the remote locks work fine, just no proximity functions (button on door, starting without it in the dash).
    #4 turbo5spd-prius, Jun 29, 2024 at 8:43 PM
  5. Tombukt2
    Tombukt2 Senior Member
    8,876
    1,549
    Durham NC
    Have you replaced the case that's on the fob did you forget the transponder chip?
  6. turbo5spd-prius
    52
    United States
    No, I hadn't. I just found the problem. Apparently I accidentally hit the "key" button under the dash recently fumbling for the hood latch at night.
    Solved.
    Thanks everybody for your input.
  7. Tombukt2
    8,876
    1,549
    Durham NC
    Yep that's pretty common.
