Smart Key
Discussion in 'Gen 2 Prius Main Forum' started by Stevep, Oct 21, 2005.
  1. Stevep
    Stevep Junior Member
    77
    Orlando, Fl
    Good morining all,
    I just picked up my 05 prius yesterday and I am in the process of doing my homework, by reading the owners manual. I got to the portion on unlocking the doors with the Smart Key function. I want all of the doors to open when I open the drivers door. There is a section in the manual that tells you how to do this (page 31). The problem is, that when I try to follow the directions, it doesn't work. Does anyone have any info, or can tell me what I am doing wrong.
    I am sure I will have many more questions, for all of you experienced prius owners, in the future.
    Thanks in advance
  2. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    I would like to know that as well, since I've been unable to do this yet
  3. nctalkinghead
    nctalkinghead New Member
    17
    Procedure in manual worked for me: Hold down LOCK and PANIC buttons together for 5 seconds. This will change it from one setting to another, as listed on page 31.
  4. lbligh
    lbligh Member
    137
    24
    Northern Virginia
    I have successfully done this. It took two or three tries, but it was well worth it. No special words of advice, just follow the directions and don't rush or freak out. Good luck!
  5. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I've got some:
    If you are with your wife and she's going to get to the car before you, press the button on the fob. After the third or fourth time of standing there, trying the door, and having to wait for you, she will quickly become iritated.
    At least that's my experience. :mellow:
  6. maggieddd
    2,090
    Boston
    I just tried it and it worked
  7. shawn7
    shawn7 New Member
    55
    Beaufort South Carolina
    Just tried it, and it worked. No special trick. I counted to 5 and tried it.
    ~Shawn
  8. 8AA
    8AA Active Member
    550
    62
    Maryland
    I think the most common problem is being impatient. Hold both buttons and count slowly to five, then continue holding the button for a couple of more seconds. Eventually it will beep back at you, but it does seem to take a long time.
  9. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    Thanks for the tip. That was cool.
  10. Ryououki
    Ryououki New Member
    I'm trying to get this to work on my 04 Prius. The instructions are in the booklet. However, when I try it, it doesn't change the unlocking ability. I have a base model Prius that doesn't have the nice buttons on the door handles. Is that why it does work for me? Also, the Panic alarm activates during the procedure, is that normal? Thank you!
  11. aaf709
    3,862
    2022 Prius Prime
    I'm afraid that's the reason. It won't work with the base level, only with Smart Key.
  12. Ryououki
    Ryououki New Member
    Awww :( Damn my stupidity for buying the base model.
  13. mmfjj
    mmfjj Junior Member
    22
    PA, USA
    On the Prius Classic (mine is 01), one click opens the driver door and two clicks open all doors. Does it not work like that any more on the base model?
    I've ordered an 06 with Package 6 but I will be keeping the 01. This smart key thing will probably require several spouse training sessions. ^_^
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    It's still the same when you use the buttons on the fob. I just went out and tried it on my 05 and I have the smart key system. When you become accustom to the smart key system you may find, as I have, that you don't use those buttons any more. Check your owners manual carefully though because the smart key system can be set up to operate three different ways (the salesperson won't know that most likely). The owners manual tells you how to set it up using the fob. One way smart key opens all the doors, another way it only opens the drivers door if you are standing by the drivers door and all the doors if you are standing by the passengers door, the third way I can't remember.
