Smartkey help!
Discussion in 'Gen 3 Prius Technical Discussion' started by viprius, Jul 19, 2009.
  1. viprius
    viprius Junior Member
    46
    Southern California
    Hi -
    I am not sure what I am missing here. Please help me with GEN III prius smart key. I have III with Nav.
    1. I thought if I keep the key in my pocket and pull the drive side door handle the door will open. The door is NOT opening! :mad:
    I have to use the unlock button on the key to open the door.
    Please let me know if I have to program this function.
    2. Also, now when I get out of the car and I want to lock the car by just touching the door handle, car starts BEEPING continuously (like PEEEEEEEEEEEEEEEEEEE).
    Please help.
  2. LaurieTx
    LaurieTx Proud new owner!
    97
    I don't have mine yet, so I'm certainly not the expert, but is the 2nd fob by any chance inside the car when you are trying this? If it is, I believe you have to use the buttons on the remote.
  3. TKY
    TKY Member
    232
    25
    Colorado
    This may not be help for you. I am not experiencing any of the issues you describe. My driver side door is unlocking as it should and opens fine. I have not needed to use either the lock or unlock buttons on the SmartKey. And, when I exit the car and touch the lock, it locks with the single indicator tone.
    The previous suggestion about the second SmartKey location would be my guess. --TK
  4. viprius
    46
    Southern California
    Thanks.
    My second FOB is indeed inside the car. I have not yet taken it out of the vehicle.
    I will give a try and see how it goes.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    913
    251
    Surprise, AZ (Phoenix)
    All fobs must be outside the vehicle as the system must "think" the car is unoccupied before unlocking the doors.
  6. hschuck
    hschuck Member
    385
    17
    bay city, ca
    The second fob being inside the vehicle is the cause of the long beep you have heard when attempting to lock with a door handle touch.
    You will also get that same long beep if you attempt to lock with sks and a door or the hatch is not completely closed. You need to determine which is the cause and correct it. SKS is just trying to help you get things right.
  7. RobH
    RobH Senior Member
    2,368
    970
    70
    Sunnyvale, California
    One requirement of using the remote/proximity functions of the smartkey is that the car is turned OFF. If it is ON in any of the three modes (ACC/IGN/READY), then the car cannot be locked/unlocked with the smartkey. When I leave the car in gear and ON, it sounds the PEEEEEEE as soon as I open the door.
    There are two rather confusing modes that you can get into with the smartkey. If you don't press the brake while pressing the Power button, the dash will light up almost normally. But the Ready light will not be ON, and the car cannot be put in gear. This actually gets easier to foul up after a little experience. You rather automatically press the brake and Power button at the same time, and you end up in one of the "halfway ON" modes because you actually hit the Power button before you hit the brake.
    The various modes are historically related to the modes on conventional cars.
    Starting in OFF, pressing the Power button gets you to ACC mode. This is like inserting the key, and turning it to the first click (accessories only).
    While in ACC mode, pressing the Power button again gets you to IGN mode. This is like inserting the key, and turning it to the second click. The dash lights up, but since the engine isn't running, you're still not going anywhere.
    And finally, pressing the brake and then the Power button gets you to Ready mode. The dash lights up, the Ready light lights up, and the engine will run if it needs to. Typically it will be a few seconds before the engine actually starts. But the car is ready to move on battery power even before the engine is running.
    Pressing the Power button while in Ready mode turns everything OFF.
    OFF is a condition that is not always obvious. The main indicator is that all of the dash indicators are also OFF (except maybe the blinking security alarm icon). The engine cycles ON and OFF when the car is in Ready mode, so it can seem like everything is OFF when in fact it is ready to go.
    You can lock the car with the mechanical key when it is in Ready mode. This is useful when you want to leave the A/C on during a quick visit to an ATM or whatever. Just be sure that the car is in Park and the parking brake is set.
  8. viprius
    46
    Southern California
    Thanks everyone for help. I took out the FOB from my car and now smartkey is functioning fine. :)
  9. wave_slider
    wave_slider New Member
    201
    26
    the aloha state
    It really is a smart key! Won't let you lock it in the car.
  10. yardman 49
    yardman 49 Active Member
    606
    76
    Northern Kentucky
    I've been renting Priuses lately for work, since I like my own so much.
    The rental company usually hides the spare fob in the car somewhere. I have to find it and keep it with me so that the SKS will work properly. Also, so that someone doesn't break in and drive off with the car and my luggage!
  11. mdeguzman0916
    mdeguzman0916 New Member
    23
    Bay Area
    also i dont know if its the same thing for 2010 priuses or prii but in my prius or the 2005 to 2009 prii theres this button on the bottom part of the steering wheel that says key and it has a button to press and when u press it, u have to press the unlock button on the smart key to unlovk it and u have to put the fob in the key slot to start the car.
  12. Sahko
    Sahko New Member
    Netherlands
    Re: Smartkey - waterpoof option
    I am on the verge of ordering a 2010 Prius, but have one question related to this thread.
    Is there a way to leave the fob inside the car and lock it with the "mechanical key", which is housed inside the fob?
    If you are wondering why one would want to do this: When going surfing, you can put the mechanical key in your wetsuit. The fob is too big for this, and - I suppose - not waterproof.
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,052
    Northern Michigan
    The button has been removed for the 2010 Gen III.
    Tom
  14. qbee42
    18,058
    3,052
    Northern Michigan
    Yes, you can do that. If you want to keep someone else from using the fob if they were to break in, you can wrap the fob in metal foil or put it in a metal box. Even without doing that, you can lock it inside using the mechanical key.
    Tom
  15. wave_slider
    201
    26
    the aloha state
    That's how I do it when I go surfing.
  16. Sahko
    Sahko New Member
    Netherlands
    Ok thanks qbee42 and wave-slider. Was a little bit worried about that, but happy to hear that's no problem.
  17. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I want to know where in the Netherlands you surf?:confused:
  18. MidWestGirl
    MidWestGirl New Member
    50
    Kansas City
    I wasn't sure where to put this question so hopefully no one minds that I ask it here. The panic button on my fob does not work. Is this the norm and I have to customize it myself or did I just get a faulty fob? It locks and unlocks without any problems.
  19. jim256
    jim256 Member
    317
    69
    Eastern NC
    Are you pushing and holding the panic button? If so, and there's no alarm then something's defective and the dealer can help. Otherwise, just hold it down, as it's designed to avoid unintended activation.
  20. rsg
    rsg Member
    64
    Harrisburg, NC
    One quick question -- let's say that my wife gets into the Prius (I have a 2011 Prius III) but doesn't have a smartkey with her (she forgets to put it into her purse, and doesn't realize that she doesn't have it).
    I walk with her to the car, the doors unlock because I have my smartkey with me, and she gets in. She buckles up, puts her foot on the brake and turns on the car with the power button (I'm still standing near the car).
    I give her a kiss through the window, and she then backs down the driveway. I wave and go into the house.
    Does the car keep running without a smartkey present? If so, what stops someone from stealing the car by running to the car, jumping in, and starting it and driving away?
    Obviously, if the car is turned off, it can't be restarted without the smartkey (I hope).
    Shawn
Loading...
