Smarty-Trend head unit
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Revell, Aug 22, 2024.
  1. Revell
    Revell Junior Member
    sweden
    slfare likes this.
  2. Revell
    sweden
    Well I suppose I'll be the first. Ordered one just now. I'll let you know how it turns out :)
    bisco and Burna J like this.
    52,519
    it looks great, all the best!
  4. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    There’s a lot of people who bought an android unit and the buttons take a second to respond and UI is super slow when transitioning
  5. Revell
    sweden
    Yes, that is why I bought the high performance alternative: 2.7 GHz Octa-core with 12Gb RAM. It has more power than my current phone :LOL:
  6. Revell
    sweden
    Update! After ordering I got an email from seller saying my unit was not in stock in Europe and they had to order from China. It was going to take 2 weeks and then they needed 1 week for testing before shipping to me. They gave me the option to cancel the order which I did not do.
    After a week or so I got a tracking number for DHL that did not update for yet another week. Then the package started moving from Germany to Sweden where I live. Got it yesterday and I was very excited. The box looked a bit banged up but not too bad. Opened it only to find contents was a ghillie suit :eek::confused: No stereo in sight... Mega bummer! So I took some pictures and emailed the seller.
    Currently waiting for a response.
    Have a nice weekend guys! :D
  7. Revell
    sweden
    They replied now that they will investigate but they will also send a new one directly.
  8. Prieth
    Prieth Junior Member
    17
    NM, USA
    Looks nice. Let us know how you like it, hopefully not too much longer.
    I just bought an 9" Ekiy T7 unit for my C, should be here by the end of the month. It is supposed to come plug and play, with the harness built and full dash panel for an oem install look. They have it as a regular double din install too. They also have the 360 bird eye cams that I'm looking forward to using. $300 all in, should be a nice tech refresh for a ten year old car.
    Another that is well reviewed is from Atoto, they have a 360 setup that only needs one camera that would make install a bit easier. It's a universal head unit and I wasn't finding any good dash kits for my car to get the clean look I want, and their system would've been about $100 more. Atoto also has a couple Linux units that will do SiriusXM if that's needed, and they're cheaper, the Android units won't do satellite.
    For anyone looking there's a handful of companies that have good reputations for the Android units, and so, so many scammy sellers. A lot of them have been found to spoof the specks to make the units show better than actual hardware or software. Most of the legit units will be running Android 10, one or two companies have a unit running Android 12, if you see claims of newer software be sceptical and look deeper into it. XDA has some good info about uncovering the scam stuff.
    They're are several nice units available for typical single/double din, or with specific kits to give the oem look and simple plug and play installs. Joying, Atoto, Teyes, Ekiy, and a couple others that slip my mind seem to keep a good reputation.
  9. Revell
    sweden
    The package finally came! And this time there was a head unit inside and not a piece of clothing :D. The plastic frame has the wrong color which is disappointing since I provided a photo of mine when ordering. Hopefully they will send me the correct one when I tell them. Everything else seems to be correct. I'll begin the install tomorrow. More details to follow. IMG_20241016_195115.jpg
    Burna J likes this.
  10. Revell
    sweden
    Sorry about the delay. I got sick and then had to catch up on work. Anyway I have installed the unit. Connecting all the cables was no problem. There were lots of other problems thou :confused: The biggest one being a very strange behavior of the volume control. There are two volume controls (for lack of better term). One is the Android control and the other can be found in an app called "Car settings" and "Amplifier settings". When I increase the Android volume the other one increases too, 1:1. So far so good. But then when I decrease the Android volume, the other keeps increasing for 8 steps before it starts decreasing. So when the Android volume is at zero the other one is at some value larger than 0 and I can't lower it any more using the steering wheel buttons (or the volume control in Android. But there is still music coming from the speakers). I have got to go in to the "car settings" > "amplifier settings" and lower that to 0.
    So every time I increase the volume and then decrease it, the lowest system output will be higher then the time before. Also the first 8 presses on volume down actually increases the system output because the "Amplifier settings" volume has more "weight" then the Android one.
    I've reached out to the supplier and he's looking in to it but nothing has come of it so far.
    Also the frame does not fit because one of the mounting "ears" are too big so it is interfering with the Prius panels. I think this is an easy fix, I can just cut the frame a bit.
    The DVR camera was not working but I just had to install the app located on the memory card of the camera.
    The sound from my speakers was terrible. Distorted. But I fixed so now it sounds great. In the Android settings and the sub menu "Sound" there is a setting for "Amplifier condit". I think this is the strength of the audio output to the JBL amplifier and has to be tuned just right.
    There is a very good looking app where I can tune the sound with an equalizer and lots of other settings. Unfortunately when setting the fader to send music to the rear speakers all the speakers go quiet. If I set the fader to 0 then there is sound in both the front and rear speakers. The funny this is that if I leave that app and just go in to the settings there is another fader that works perfectly :ROFLMAO:
    I haven't gotten around installing more interesting apps because if that volume control issue can't be fixed then I want to send it back.
  11. Revell
    sweden
    It has been fixed! Their support got back to me and the problem was that the wrong CAN protocol was selected. For the 2012 Prius I'm supposed to use RZC(Raise)>Toyota>Camry>2018. Now the volume control works fine!
  12. TomS
    TomS New Member
    Belgium
    Does your car have a factory reverse camera? If so, does it work with the new stereo?
  13. Revell
    sweden
    Yes, it works with the factory rear camera. It comes on instantly when I put the car in reverse. Works with the JBL amplifier and steering wheel buttons too!
  14. slfare
    slfare Member
    64
    136
    Portland, OR
    This looks really good and exactly what I have been looking for! I just purchased the 9.5” unit and will report back once installed!
  15. slfare
    slfare Member
    64
    136
    Portland, OR
    Okay, I finally completed my SMARTY Trend head unit installation!
    Everything works! I have a Prius 4 with the JBL amplifier and the sound is amazing! All steering controls work, backup camera, voice assistant for Siri, mode to switch to radio, etc., forward and back track buttons. The built-in microphone is good enough for voice control and phone calls! I might revisit attempting to wire the microphone to the factory one, but I'm not sure it's worth it.
    The installation instructions are not great, but information is out there and I'm so thankful to you, Anders, for the great help and introducing this head unit to the forums! Support is also very good via WhatsApp.
    They sent me the wrong cable harness, so while I was waiting for them to send me the correct one, I went ahead and purchased one from eBay just to make sure I would have the correct one in case they sent me the wrong one again. Which, I believe, they did because the replacement was missing one connector. I was able to connect all connectors coming from the factory harness.
    And yes, that yellow RCA connector that gets connected to the head unit needs to be connected to the male end coming from the aftermarket harness.
    The fascia snaps right into place to the dash!
    You need to cut a small portion of the power cover so that the left "ear" of the head unit can fit. This was achieved using a box cutter and a lot of patience!
    I kept the USB that's inside the armrest and also ran the other USB cable through the floating center console and out the bottom for a really clean install!
    I was really impressed with the way it integrates with the car! For example, it tells you when doors open and integrates with the climate control!
    The display is truly gorgeous and brings new life and functionality to my beloved Prius!
    In the end, I am very impressed with this head unit! It met all of my requirements and expectations! This has added great functionality, safety, aesthetics, and life to my beloved Prius!
  16. AzusaPrius
    AzusaPrius Senior Member
    2,245
    933
    After finding out about this company from this thread, I have been trying to contact them.
    I want to buy the Tesla style 10"
    I have searched online about this company and it is hard to find a lot of reviews.
    Some forum stuff about the brand.
    Their social media has a small presence.
    All the scam alert websites say it is LEGIT.
    They have been online since 2016
    Communication with them is slow and slim.
    I hit them up on IG, email and I even downloaded Whatsapp just to message them, also their website chat is always offline.
    Most communication from them was through email. I got one response on IG and no response through Whatsapp yet.
    Makes it hard to trust them and to have an order come with wrong parts or even worse, not the item at all.
    Then there is the long distance warranty issue and the radios are not cheap.
    I would say be cautious about a purchase.
  17. misterduck
    misterduck Junior Member
    Earth
    slflare, amazing! I really like it. If you don't mind, would you share the precise stuff you bought to get it all working? I'd really like to drag my prius into 2025, and this looks like a great avenue by which to do that.
    slfare likes this.
  18. slfare
    slfare Member
    64
    136
    Portland, OR
    Thank you and a big thank you to Anders (Revell) for recommending the head unit! All I purchased was the head unit (2K model top of the line) and the harness from eBay that I linked. That’s it! Everything is plug and play; nothing to splice and you don’t even need to disconnect the battery! Let me know if you have any questions and cheers to bringing your Prius to 2025!
  19. ProjectPriusPro
    ProjectPriusPro New Member
    Topock, AZ
    Hello.
    Can you guys tell me (either from looking at the settings on your unit or from purchase experience), if the 4 x AHD 1080p 360 cameras that connect to this head unit are PAL (25FPS) or NTSC (30FPS), or if this setting can be changed within the 360 app to work with either version? Thank you!
    JJ
  20. Revell
    sweden
    - I have not purchased the 360 cameras, so I cannot help you, unfortunately. Have you figured out?
