Smog check after P0420 fix
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Swiick, Aug 12, 2023.
  1. Swiick
    Swiick New Member
    NorCal
    I recently installed the spacer on the 02 sensor to get me through until I can afford a new Cat so I can pass an upcoming smog check. I cleared the DTC and drove a few miles and the CEL hasn’t come back on…yet. Do I need to wait until I see it come back on or not to get it smogged or if the fix worked I should be able to smog it as soon as I want?
  2. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    You will automatically fail the visual inspection portion of the test.
  3. Swiick
    Swiick New Member
    NorCal
    Oh okay that makes sense. I’m guessing most smog places know to look for the spacer “fix”?
    #3 Swiick, Aug 13, 2023
  4. smwalker
    smwalker New Member
    Azusa, CA
    Yea it's a common thing inspectors find and fail on. There are lazy inspectors though, probably got a 30% chance of passing.
  5. AzusaPrius
    AzusaPrius Senior Member
    1,820
    809
    My smog tech only looked under from the drivers side and did not even care I had a cat shield on it.
