Smog check fail - OBDII Monitors Not Ready
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by quack724, Jul 21, 2020.
  1. quack724
    quack724 Junior Member
    Hi ,
    I have 2010 Prius that failed for Smog check today. I believe everything passed except the "OBDII Monitors Not ready." See attached photo for details.
    Just over two weeks ago, we had the car serviced for the JOV engine recall where they performed a software update and oil change.
    And just before that, our 12V battery died and I replaced the 12V battery myself.
    So at a minimum, I think the 12V battery replacement is the root cause of the "Not ready"?
    I've been reading other threads and the 3rd party Smog test shop I went to suggested driving the car as normal for about 30 miles or so? But then I read other general articles where they seem to have very specific sequence of steps (I cannot link because I am new).
    I have to pay for each smog check and at the same time, I don't want to buy an OBDII device to check the readiness so I just wanted to know if driving the car as normal for about 100 miles should get the car to be in "ready" status?
    Thank you in advance !
  2. AzusaPrius
    AzusaPrius Senior Member
    1,819
    809
    Yes put some miles on it like 100-200
    It will be ready then.
    Also you should only go to pass or dont pay smog stations.
    Even then if it is not ready they should not be charging you anything.
    You paid someone already then go back to them after the miles you are doing to get it ready for smog.
    The recall and battery replacement reset the computer so it needs to be driven a good amount to see if any faults show up.
    Bbonez, pjksr02 and quack724 like this.
  3. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    That seems like an odd not-ready, especially if the catalyst monitor completed and passed.
    Check out the drive pattern below (idle 9 minutes and drive for 2--this may be for older Prius years). Maybe Autozone will read your readiness monitors for free, like they look at check-engine codes.
    Maybe the sensor is on its way out--how many miles on the car?
    Toyota Drive Cycle OBDII Readiness Monitors - A Star Smog - Antioch Smog Check
    #3 pjksr02, Jul 22, 2020
    quack724 likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    I remember the last smog check I got on our old 2010 that I had pulled the 12 volt lead prior to going to the smog shop:whistle:.
    Had a 40 mile run to get to the shop and all the monitors were ready:).
    You could always try @Joele3 's shop in San Ramon for a smog. Helps a local member too;).
    And he's done a lot in the space of Prii (engine swaps, oil catch cans, multiple generations), so a good one to chat with(y).
    #4 Raytheeagle, Jul 22, 2020
    bisco and quack724 like this.
  5. quack724
    The car has just over 144K miles.
  6. Mayank Jain
    Mayank Jain Member
    99
    70
    Cupertino, CA
    I just went through this yesterday.
    After covid-19 lockdown, I started my car to find a dead battery. Replaced it with a new one.
    Then for DMV registration, smog check failed - OBD-2 not ready (same as above).
    The mechanic said to drive 100+ miles. I drove on local streets & highway to give the Prius computer exposure to all sort of road conditions.
    SMOG check passed yesterday after driving 105 miles.
    I hope this helps someone in future.
  7. fuzzy1
    10,138
    How many miles have been driven since these events?
  8. quack724
    My apologies. I meant to update this thread earlier. We drove about 300 miles since the 12V replaced and first smog check failure. On the 2nd try, our smog check passed. I think I may have been able to bring it back sooner than 300 miles but I had time before our due date and I didn't want to risk a 2nd smog check failure again.
  9. bisco
    49,357
    i can't believe disconnecting the 12v erases all the emissions data...
  10. better call Saul
    better call Saul Junior Member
    Portland
    Have you tried replacing your gas cap with an OEM gas cap?
