Smog check now required for hybrids in CA
Discussion in 'Generation 1 Prius Discussion' started by DaveGoodrich, Jun 19, 2015.
  1. DaveGoodrich
    DaveGoodrich Member
    141
    68
    I have loved the fact that we have been exempt from smog testing in CA. This was because these cars would shut off when idling, so there was no way to do the tailpipe sniffer test. However, the latest test procedure/equipment just connects to the OBD to interrogate the internal diagnostics (along with a visual inspection to verify nothing has been tampered with). So, beginning with vehicles with registrations due in July, 2015, a smog test will be required every 2 years, and upon change of ownership.
    Fortunately, mine was renewed in June, so I am good for another two years (if it makes it that long given it has 370k miles on it now).
    #1 DaveGoodrich, Jun 19, 2015
    52,373
    there should be a grandfather clause.
  3. JC91006
    16,827
    8,600
    It's the grandfathers that have the issues
    bwilson4web and Patrick Wong like this.
  4. DaveGoodrich
    DaveGoodrich Member
    141
    68
    Hey, I resemble that remark.
  5. bwilson4web
    16,359
    I have personally worked on a 2001 Prius that was losing oil. The miniVCI showed the rear O{2} sensor was following lock-step with the front. The catalytic converter was fubar. However, it also had a rear oil seal leak, the signature of overfilled oil changes. Eventually oil got on the torque limiter and the owner finally replaced it with a NHW20.
    That car also had 'noisy' steering torque sensors. So he had a switch that powered ON/OFF the power steering ECU. The only time it was turned on was at slow speeds when parking by his wife. Otherwise, it was off but he did a lot of highway driving.
    In Alabama the only vehicle inspection is make sure the VIN number matches the title when it is first registered.
  6. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    They started smogging Hybrids 8 years or older in Colorado this year. As long as the check engine light is off you should pass. (Colorado is now using the same OBD2 test California will implement that DOES NOT use a tailpipe sniff).
    If your CEL light is on and you have a P0420 error (catalytic converter) it will be expensive to fix in California. In Colorado we can use aftermarket Cats, in California I think you are stuck with OEM which is well over $1500.
    bwilson4web likes this.
  7. DaveGoodrich
    DaveGoodrich Member
    141
    68
    I had my cat replaced with a generic several years ago, which cured the P0420, but I wasn't worried about passing smog at that time. I've never had an inspector lift a vehicle to inspect the cat, so as long as I have no code, I'm hoping I'll be ok.
  8. bwilson4web
    16,359
    Sort of like 'always' obeying the speed limit. <grins>
  9. Sandy Meyers
    Sandy Meyers Member
    153
    56
    Los Angeles
    2002 Prius
    I
    I had my 2002 Prius smogged for the first time at 93,000 miles in California since it was required, and it passed, of course! Why wouldn't it? Love my Prius!
