smog issue - practical ideas?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pri2004, Nov 2, 2016.
Tags:
  1. pri2004
    pri2004 New Member
    california
    So, here in CA you need to smog before selling, and the engine light is stuck on.
    seems it needs a new cat converter. the car runs beautifully, even at 200k+ miles.
    can't see spending $2000 for new cat, and can't bare the thought if car getting junked.
    need to smog in 8 months anyway.
    sell it in texas? sell it for parts? pragmatic ideas appreciated.
    #1 pri2004, Nov 2, 2016
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
  3. pri2004
    pri2004 New Member
    california
    illegal in california to buy and install used cat converter
    05PreeUs likes this.
  4. kenoarto
    398
    Chicago, IL
    links are to new converters.
    have you gotten multiple bids from Midas, CarX etc?
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    It's actually a violation of FEDERAL Law, but most states don't care.
  6. JC91006
    16,773
    8,568
    I'll buy it if it's cheap enough, as is
  7. pri2004
    pri2004 New Member
    california
    if you see the verbiage on the vendor in ebay with new cat converter , it is 49 states only. different emission standards here. i assume other cat converters are the same.
    Can a California member chime in ? If there is a cheap new, CA-compliant converter, the folks at my trustworthy (i think) hybrid-only repair shop don't know about it.
  8. fuzzy1
    10,486
    California is not one of the many states that doesn't care.
  9. pri2004
    pri2004 New Member
    california
    it seems illegal to sell it, but not illegal to buy it
  10. JC91006
    16,773
    8,568
    I just need it for parts
  11. 05PreeUs
    1,097
    564
    MSP
    None of the CARB buy-in states are ;)
  12. pri2004
    pri2004 New Member
    california
    sorry, i don't understand "CARB buy-in states"
  13. JC91006
    16,773
    8,568
    You can clean your catalytic converter and It'll pass California smog
  14. CooCooCaChoo
    CooCooCaChoo Senior Member
    957
    535
    Cow-lee-fornia
    2023 Prius
    Or you can find some other Prius owner and swap exhaust for the sole purpose of smogging, then swap back.
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    No aftermarket Cat is legal in CA or NY. Toyota is the sole source in those two states.
    Catalytic Converter Database
    There are OEM fit cats for under $300 for the other 48 states.
    http://www.carparts.com/details/Toyota/Prius/Eastern/Catalytic_Converter/2004/EAST40712.html?TID=gglpla&origin=pla&gclid=COr3i7L6itACFQcIaQodmLUMtg
    For $1500 you can get a Toyota part
    2004 Toyota Prius Base. #1741021500: Catalytic Converter. Exhaust pipe. FRONT PIPE. Incl.Resonator
    Selling (or repairing) your Prius out of state may be the answer.
    #15 JimboPalmer, Nov 2, 2016
  16. pri2004
    pri2004 New Member
    california
    well, i hoped to get more practical ideas from this well informed, helpful bunch. but i guess the awards go to jimbo and jc91006. I'm not a DIYer, just a driver.
    1st - cleaning the catalytic converter so that it passes smog sounds lovely- but is there a technical basis for this ??? what % of success, and who will do it ? if I drive to LA, will you do it? how much do i have to pay? ( 1/2 serious) anybody want to chime in?
    2nd - repairing the and selling the car out of state seems to be the only purely legal way to do this. I think its legal, does anyone have a comment on this?
    Many people will be in this same situation very soon, so it is not a fringe issue. on another thread I saw this posted:
    Apparently you can not buy or install those cheap $100-$300 weld-in or even direct fit aftermarket "49 state" parts legally, and SMOG TECHNICIANS have been warned and trained to look for proper markings "CA COMPLIANT OBD II" or whatever it is they look for -- so don't expect to get away with that, either.​
  17. JC91006
    16,773
    8,568
    To clean it, you would need a mixture of 2 acids.
    use 1.5 lbs of pure citric acid powder and 1lb of pure oxalic acid powder. That is pretty close (not exact) to what the formula requires for about 9 gallons of soaking solution.
    There are youtube videos on this
  18. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    drive it to Nevada and have it fixed or clean the cat
