Smoke in prius gen 3 cabin after a little blast
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Billtariq, Jul 6, 2021.
  1. Billtariq
    Billtariq New Member
    Pakistan
    Hi all hope you are all well, i was driving my prius gen 3 1800cc 2010 model on the road suddenly i heard a little blast like small juice box exploding. After 2 to 3 sec the whole cabin wasfilled with moderate smoke. Previously i had replaced its eight battery cells the car was working fine. i had lilltle hit on catelic converter it was also sounding odd For 2 months when car is idle. Now the car is getting load while driving. its milage is 10 to 12 km/l in city. And now i am worried what it can be? Please help me with your expert openion.
  2. PriusCamper
    PriusCamper Senior Member
    11,093
    4,515
    Pacific Northwest, USA
    If you've already replace cells in the hybrid battery pack, I suspect that you have more failed cells. So start your search there... Do you have any leaks in your exhaust system? Possibly your exhaust manifold flange gasket where catalytic converter connects has failed.
    Billtariq likes this.
  3. Billtariq
    Pakistan
    Yes i hope its the battery system issue i will check the catelic gasket aswell becuse the car sounds like a sports car when on engine.
    Can i drive car in maintainace mode just to reach service center?
  4. ChapmanF
    15,569
    Sounds a bit like rapid unintentional disassembly of a module.
  5. bisco
    49,443
    yes
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    And someone stole your cat.
  7. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    o_O
  8. ASRDogman
    ASRDogman Senior Member
    6,085
    3,271
    Toyota plainly says NOT to drive the car in Maintainance mode. But it's your car...
    Grit likes this.
  9. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    yep, and manual says not to jump other vehicles also. And people still do, just suggestions and opinions :LOL:
