  1. Blurredforlife
    Blurredforlife Junior Member
    71
    Chicago
    I was prius camping over the holiday. I had been leaving the vehicle on for most of the weekend. My 2012 pruis has 117642 miles. Drove from Ohio to Chicago with no problems and it hasn't smoked since. It does use oil. I have to add oil at every fill up. Usually between a half quart or half of a half depending on how much highway miles I'm driving. Any ideas...It had been raining and it was in the 50s to early 60s temp outside. Screenshot_20210608-193411_Gallery.jpeg Screenshot_20210608-193356_Gallery.jpeg
  2. Blurredforlife
    71
    Chicago
    It hasn't lost coolant and it didn't smell like coolant. Really didn't have an odor.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,963
    4,709
    Texas Hill Country
    White smoke?
  4. Blurredforlife
    71
    Chicago
    Looked like it. Didn't seem blue.
  5. bisco
    49,443
    have you done the egr circuit cleanse?
    Blurredforlife and Mendel Leisk like this.
  6. rjparker
    7,963
    4,709
    Texas Hill Country
    I would watch the coolant and hope you don't get any cold start shakes.
    Blurredforlife likes this.
  7. Blurredforlife
    71
    Chicago
    I didn't clean the egr tank but cleaned the pipe and intake manifold.
  8. Blurredforlife
    71
    Chicago
    Ive been keeping my eye on it but it hasn't moved
  9. Blurredforlife
    71
    Chicago
    Looked like it but didn't smell like coolant
  10. Blurredforlife
    71
    Chicago
    Are talking about the egr cooler tank?
  11. privilege
    privilege Active Member
    659
    169
    Birmingham
    half a quart per 400 miles =
    a lot of oil burning between changes
    yes I would expect to see it smoke occasionally. you usually don't see it because.... well... it's heading the opposite direction of where you're looking, and it's burning all the time
    how's your compression ?
    have you tried any of the snake oil products that claim to unstick rings ?
    might not be a bad idea to soak each cylinder with atf+acetone over night and then change the oil a couple of time to flush the magic stuff out.
    I'm assuming your rings are just stuck and not weak tension
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Straight ATF or Marvel Mystery Oil might be a better choice since you don't have to worry much about "flushing" it out afterwards.
    Applied when the engine is hot.....or at least warm.
  13. Priusjames
    Priusjames Member
    92
    67
    Irvine, CA
    +1 on Marvel Mystery Oil.
    Blurredforlife and StarCaller like this.
  14. bisco
    49,443
  15. Mendel Leisk
    38,709
    If I may jump in, thorough cleaning of everything between the connection of Exhaust Gas Recirculation system at the the exhaust manifold and the engine intake ports.
    more info:
    Bad Flywheel | PriusChat
  16. Samuel Williams Jr
    246
    Dayton NV
    Generally speaking smoke, if it's blue is oil burning and smoke if it's white is coolant. It's pretty much that simple. I'd say you have a "failing head gasket." It looks like a micro leak now, but it's not going to heal itself.
    I'll second a compression test being done. More than likely one cylinder is down on compression or easier still just pull the spark plugs, the cylinder that is burning coolant will be cleaner then the others.
    If you address it early, it's just a Head Gasket R&R, if you wait to late you'll need to source a motor.
    Valiant V and Blurredforlife like this.
  17. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    head gasket in the way out and major oil consumption, great canidate to trade it in now with used market as it is. Yes, please come arrest me the karma and moral police.
  18. bisco
    49,443
    Oh great, soon there’ll be a new thread:
    ‘Hi guys, I’m the excited new owner of a 2012 Prius with 117,643 miles, and i've heard that these cars can go a half million miles.
    i'm so glad i found this community, and I’m wondering if anyone knows what the white smoke coming out of the exhaust is from...'
  19. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  20. rjparker
    7,963
    4,709
    Texas Hill Country
    More like:
    ‘Hi guys, I am looking at a 2012 Prius with 117k miles and I have heard that these cars can go a half million miles. The car runs great and and is a steal in today's market. Any advice?'
    and he will get:
    My 2010 with 110k is wonderful, does not use oil and I have never had a problem. But clean your egr system.
