Smoking cigarette lighter plug.
Discussion in 'Prime Main Forum (2017-2022)' started by EyePrime, Jun 25, 2020.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Today I was checking my dashcam and noticed it hadn't been recording for the past 2 weeks, and found out that the front seat cigarette lighter plug thing wasn't working. I thought that It was probably just a blown fuse. I plugged it into the rear seat cigarette plug and the port/plug the started smoking. It made a horrid smell and I immediately unplugged it.
    Im not sure where the fuse interior fuse box is. And Im very worried about the smoking plug. The charger plug also wasn't cheap, so I don't believe it's the chargers fault.
    (Btw the front cigarette lighter never smoked up)
    Please Help.
    Please ask if you need clarity or have any questions please ask.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    If the car is still under warranty. Take it to the dealer right away. If it's out of warranty, take it to the dealer anyway. Fire is nothing to mess with.
    pghyndman and Elektroingenieur like this.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I do. You said the cam was plugged into the both and then both had issues. Simple logic says suspect the dash cam first.
    MrBugMan, Majafamily and pghyndman like this.
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    @jerrymildred's kind suggestion to have a dealer—or an independent shop, if warranty coverage isn’t a factor—look at the car right away is a good one. If that’s not possible, you might consider temporarily pulling the P/OUTLET NO.2 fuse, as described in my previous posting. The rear power outlet is the only load on that fuse, so removing it wouldn’t cause any other problems.
    EyePrime and jerrymildred like this.
  5. jerrymildred
    11,517
    14,158
    Tampa, FL
    Thanks. Forgive my "Oh my gosh!" initial response. Pulling the fuse really would be the first thing to do. And then get it checked by someone who really knows what they are doing. Fire in a car isn't quite as close to certain death as in a spacecraft, but it's still really really bad.
    It does seem like the dash cam pulled too much current, but the fuse should have blown. Perhaps someone had alreay replaced it and put in a bigger one? I'd check the fuse rating against the chart on the fuse box lid.
    pghyndman likes this.
  6. NSXT
    NSXT Active Member
    137
    119
    Toronto, Canada
    2018 Prius Prime
    Speaking of it, I remember we had it plugged in once (rear seat 12V) and a smoke smell came out of it (done by my back seat passenger) and we thought it might have been a bad 12V USB plug so we threw it away and never went back to test. I think I should have the dealer to check it out at my next service. :eek:
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    I agree that the plug/camera is suspect and not the actual socket. I would think the camera power cable or plug has an internal short, as I just can't see the camera itself drawing any significant power. Perhaps the smoke came from the plug and not the socket?
    A cigarette lighter circuit is designed for a relatively high current. Those elements get red hot. I think it's more likely that a low current is smoking something in the camera's cord/plug.
    jerrymildred likes this.
  8. EyePrime
    268
    115
    2018 Prius Prime
    Sorry, when I plugged the plug into the rear port. It started smoking withouT the dashcam pluggedin. So the cigarrete socket to usb was plugged in to the cigarette socket without anything in the usb side
  9. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    So it is likely that the "cigarette to usb" adapter is the source of the problem?
    More 'Made in China' adventures?
    Tips and fotomoto like this.
