Snapped off threaded stud that holds lug nut
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stevewoods, Aug 6, 2017.
  1. Stevewoods
    Stevewoods Senior Member
    650
    998
    Seattle, WA
    Leaving four of the the five lug nuts holding the tire to the wheel.
    I remember doing this some 20 years ago on another car. Seems it was O.K. to drive it slowly to the shop -- which is about 15 miles distant.
    I will ask when I call them tomorrow, but any opinions on a slow drive to town.
    49,694
    i hate when that happens.
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    Just make sure the others are the proper tightness and don't try to set any cornering speed records and you'll be fine.
  4. Stevewoods
    650
    998
    Seattle, WA
    Thanks for the quick responses, guys. I torqued the four remaining nuts to 78 ft. lbs.
    I have watched a couple of YouTube videos that make replacing it myself very tempting, but it is wifey's car and she doesn't trust any of my "hillbilly repairs", so unless I lie to her about having it done professionally, I am going to have to bite it and take it to the shop.
    What's wrong with Hillbilly work, anyway?
    cyberpriusII and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Maybe if you call it "backwoods engineering", she might be more receptive(y).
    Stevewoods likes this.
  6. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,139
    1,598
    Iowa
    I love Cow - A - Socky!
    I want one.
    I actually replaced the threaded stud on a car I owned several years ago. Other than the fear I would mess something up, it was pretty straight-forward. As for driving with four of the five, no experience.....
  7. ChapmanF
    15,865
    Hey, you're both somewhere in the NW ... would it be considered a hillbilly repair if Kris did it? :)
    Or, if you were to pull down the exact Toyota procedure from techinfo and your wife were to watch as you did exactly that, would she consider that a hillbilly repair?
    I'm just trying to make sure I understand what makes something a hillbilly repair. :)
    -Chap
  8. Patrick Wong
    18,200
    6,479
    I am wondering what caused the stud to snap. It seems reasonable to slowly drive to town as long as whatever caused one stud to snap didn't weaken the remaining four. To me, slow means 35 mph or less.
    Does your wife have any particular reason to distrust your vehicle repairs?
    Did the stud on a front axle or rear axle fail? If the front, are you comfortable removing the brake caliper and brake disc for access to the hub? If the rear, are you comfortable removing the brake drum? Can you obtain the correct replacement stud and stud extractor tool without having to drive 15 miles? Can you disconnect the 12V battery so that you don't end up with the skid control ECU logging DTC while you are messing around with the hub?
    Spec is 76 ft.-lb by the way.
    Probably, a hillbilly repair would be one which is performed without regard for the proper technique or tightening spec, and employs adhoc means rather than the correct tool for the job.
    So for example, if Steve were to use a sledgehammer on the broken stud in an attempt to drive it out, and in so doing damaged the hub bearing or the wheel speed sensor, resulting in the skid control ECU throwing a fit and lighting up ABS/VSC/((!))/BRAKE warning lights, then his wife could fairly describe that as a botched hillbilly repair.
    #8 Patrick Wong, Aug 7, 2017
    WilDavis, Mendel Leisk and Stevewoods like this.
  9. Stevewoods
    650
    998
    Seattle, WA
    Funny, that was just what I was intending to do...if I did it myself. Had the sledge all picked out in the workshop
    edthefox5 and bisco like this.
  10. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Using a hammer to remove the broken stud is the most common method. But there is a change that bearing can get some damage while doing that. To reduce the change for damage you can put the disc/drum and tire back in the car (or leave them on if you know at what position there is enough space for the stud to come out). Added weight will reduce the shock that the bearing gets a lot.
    johnjohnchu likes this.
  11. Patrick Wong
    18,200
    6,479
    It would be far better to use a tool intended for the job, which would push the broken stud out without any risk of harm.
    johnjohnchu and WilDavis like this.
  12. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I've heard of over-torqued studs having a tendency to snap. I cannot speak from personal experience, although I remember once fetching my old Corolla from getting it serviced (no, not the local dealer, I think it was Midas) and I just happened to glance down at the wheels ( well, you do, don't you?) and noticed that one of the (4) nuts was almost off the stud! :eek: Well, that prompted me to buy a torque-wrench, and now I always do my own! ;)
  13. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    I tend to think each part in that area is necessary, but it seems that the exact number of studs and nuts can be flexible.
    On my way from Lomé to Mango, Togo a couple years ago, the bus had a leaky right front tire. They got it to the bus station in Kara and we all stood around while they tried to change the tire. They got all the lug nuts off but one. That stud just spun round and round with the nut. We continued to wait and watch while they went and got someone with a big ol' right angle grinder.
    We eventually went the rest of the way to Mango with 10 of the lug nuts in place because, at some time previously, they had apparently already had to cut off one other stud. Unlike some buses I saw along the road, we stayed right side up all the way and never caught fire once. Another successful trip through the African bush. :D
    WilDavis and bisco like this.
  14. Mendel Leisk
    38,875
    I'd second @Patrick Wong 's question, how this may have happened: anyone else taking the wheels off?
    I'd get pros on it, myself. Google Eric the car guy stud replacement for one video.
  15. valde3
    2,002
    745
    Finland
    Of course correct tool is always the better option. But finding tools like that can be very hard as most of people just use the improvised method.
  16. ChapmanF
    15,865
    Improvised methods are great! All it takes is looking up or knowing the recommended method and why it's recommended (e.g. thou shalt not bang on thy $300 bearing) and then you're in shape to improvise a suitable method. Two C clamps and a steel bar, for example.
    -Chap
    jerrymildred likes this.
  17. Stevewoods
    650
    998
    Seattle, WA
    Thinking the failure may be related to 15 months ago (April/May 2016) when I changed that exact tire. For some reason, I did not tighten the nuts enough and noticed a few days later that they were loose. Not horribly so, but enough to make a sound when cornering.
    Tightened them to specs. Had new tires put on in August 2016. Now, this is the first time that tire has been taken off since the new tires last August.
  18. Patrick Wong
    18,200
    6,479
    Well, this is one example of a tool that might be suitable which doesn't cost an arm and leg:
    In that case I suggest you consider replacing all five studs on the wheel hub. The others may have been weakened by the loose wheel wobbling.
    I've worked on autos since I was a teenager (hence almost 50 years) and have never had a wheel stud break on a vehicle. Of course I have never lived in areas subjected to winter salt and terrible metal corrosion either. In any event I would not view a wheel stud breaking as a normal event, rather it is something that should be analyzed and action taken to replace all suspect parts. After all, you are expecting the studs to hold the wheel to the car which certainly is a safety issue.
    #18 Patrick Wong, Aug 7, 2017
    jerrymildred and Mendel Leisk like this.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,808
    Clearwater, Florida
    I lubricate the wheel studs and on a G2 I apply grease between the wheel and the hub. I leave the center cap off the wheel put it on the hub then fill that center hole with grease and put the cap back on. The hub castle nut is not corroded. First time I pulled the tire off before lubrication the wheel refused to come off. Had to drop it off the jack with nuts loose to break it free.
    The nuts on the lubricated studs have never come loose but come right off with tool. I use CSP for this.
  20. Mendel Leisk
    38,875
    Do you torque a bit lower, with the lubed threads?
    WilDavis likes this.
