Snow Driving Help
Discussion in 'Gen 2 Prius Main Forum' started by spideyman, Jan 22, 2008.
  1. spideyman
    spideyman Junior Member
    96
    Central Illinois
    I have a 2007 Prius Touring model with OEM tires and 11 k. Here in central Illinois we had about 3 inches of snow last night. I commute about 30 miles one way to work and drive home at 2 am. The area I live in has a steep hill with 2 switchbacks on it which I was unable to get up this morning at all. I was forced to park at the bottom and walk a mile home which at 2:45 am in a blowing snow storm, didn't make me any too happy. The tires on my car are Bridgestone Turanza EL400 - P195/55R16 86V. Would replacing these tires help at all? IF so, what would you guys recommend? I called the Toyota dealer, and they only have these same tires available for replacement, and so far, I am not too impressed with them.
    The car just spun and spun trying to get up the hill and it felt like the power cut out to the wheels.
    Thus far, I am not too impressed with driving a Prius in the winter time.
    The bad part is, the only other time I was never able to make it up the hill here, was when I had a truck and there was ice on the road. Any other front wheel drive vehicle I have owned made it with no problem, and we have had some nasty snow storms in the 30 years I have lived here.
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    bummer dude.... kinda wondering if any car with regular tires could have made it?
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    So a touring.
    You could try Nokian WR G2 tires, available in 205/55R16. These tires would work much better than the stock tires, and would probably get you up that hill. They are very close in diameter, so the speedo and odo should be almost right on (835 turns per mile vs 855 stock). Best part - you leave them on year round, as they don't wear out on summer roads and faster than a "summer tire".
    Perhaps you should try again with the stock tires but only use about 30% throttle. I find the car will keep trying at that throttle position, as it doesn't overpower the system. Do make sure the tires are fully inflated. In snow tires actually work better with full pressure as the tread tends to clear better. Perhaps try 40 PSI front and 38 PSI rear.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    With the traction control on the Prius, the tendency is to take your foot off the accelerator when the power drops ... DON'T. Keep your foot on the accelerator and the car will slowly gain traction.
  5. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Switchbacks without snow tires! How do other front-wheel drive cars with traction-control handle that situation?
    The typical steep climb I witness watching others is mindless spinning of the wheels until the resulting slow crawl gets them up. Obviously, leaving a slick trail of glazed road behind you isn't considerate. It's wears away rubber quickly too.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This is good advice.
    I have no experience with the OEM tires on the touring model, but the OEM tires on the standard model are terrible in snow. I switched to a good all season tire and it made a world of difference. Snow tires would do even better.
    Tom
  7. farnorthman2000
    farnorthman2000 New Member
    maine
    I live in Northern Maine( so we drive in snow ALL the time), i would suggest Copper Studdless Snow tires, they're great. I have a company pick up that i use to get to work but my wife uses the Prius daily and with the Copper studdless, never a problem. Unless of course you try to go through too high of a snow bank and get hung up because the tires no longer have traction because the car is off the ground. I think i paid around $450 for a set of 4 tires, installed
  8. YoungOrganist
    YoungOrganist New Member
    Bahstahn MA
    2002 Prius
    Definitely get snow tires! They really do work!
  9. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    My Prius is completely helpless on icy roads, or a bit of slush/snow, unless I run aggressive studded winter tires. They really do work
  10. MKL
    MKL New Member
    I had trouble with my Touring in light snow (also with OEM Turanzas) first day I brought it home. Next day, I ordered some Blizzak snow tires from Tire Rack for $80 each, and drive through 2 feet on a New England tour with no problem. Snow tires make an enormous difference!
    -MKL
  11. GigaTigga
    GigaTigga New Member
    84
    Nebraska
    I live in Nebraska, and we have snow pretty much through winter. I just got my 08 package 6 in early november. We've had a few snows since then, LOTS of ice under the snow, and while my prius (with stock non touring tires), doesn't get around as good as my f-150 4x4, it does a pretty decent job. My work van is a 01 chevy 2500, RWD, and i don't have too many issues with it, with all season tires. My mates car is a 96 accord fwd with (basically) slicks on the front, and we have no issues there either.
    A lot of people around here say the regular tires are awful in the snow, and no offense, but i wonder if its lack of knowledge about driving in the snow, or have i been lucky? I've never replaced tires on any car to drive in the snow, and as long as the snow isn't going to high center you, i can imagine with the right know-how you would be ok, am i wrong? Anyone else use the plain ol' tires that come with the prius and have no issues in the snow?
  12. jayman
    13,439
    640
    Winnipeg Manitoba
    Whatever
  13. GigaTigga
    84
    Nebraska
    Then explain it to me, why do so many people say the stock tires suck so much in the snow? A simple whatever doesn't address the issue.
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    is an explanation of why regular tires dont work well in snow and ice and that "snow" tires are recommended...
    that is like asking "why should i wear a coat?"
    well, you might be able to run around in 20º F temps in a t-shirt (i did it as a kid in alaska...) but then again a coat might be a good idea...
  15. GigaTigga
    84
    Nebraska
    Its not exactly like that. If you told me that you can not go outside in 20 degrees or else your blood will freeze within 5 seconds and you'll die, i'd have the same question.
    I'm not trying to be a smart nice person, or trying to offend people, i just want to know why everyone says the stock tires are so awful. Am i the only one here crazy enough to attempt such a feat as driving a prius with stock tires in snow?
  16. personallyuneek
    personallyuneek Yankee fan in New England
    47
    NorthEast
    At the risk of sounding trollish, let me try and help the Vegan understand. An 08 with stock tires has full treads. I own one and was able to do circles around some 4x4's in our recent 18 in snow storm (WAY COOL). The key is the new tires. Snow's are recommended because the agressive tread holds better. New tires full treads will perform similiarly to the snows. The OP has 11k on the tires. OEM Integrities with wear will probably act like IceSkates even for experienced snow drivers. It is all to do with Tread depth.
    My Body isn't a graveyard, it's a temple!
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    nope... i also drive on nothing but stock... get a lot of rain and it has snowed here more this year than any year in recent memory...but not enough to justify the expense.
    i guess what im trying to say is...if you have a problem driving in snow, get the tires... if not...dont worry about it.
    lets face it... the question you ask cannot be answered. some people cant parallel park either... so you gonna ask why??
  18. GigaTigga
    84
    Nebraska
    No i wouldn't ask why, i would just say they don't know how to park, which was my original reply to myself, meaning they must not know how to drive on the snow.
    Cute.
  19. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    127
    Papillion, Nebraska
    I live in Nebraska as well ... can I ask which dealer you purchased from? I am in Lincoln ... how did they treat you?
    Thanks!
  20. GigaTigga
    84
    Nebraska
    I bought from performance toyota, they were good to me. who did you go with? (maybe we should talk about this outside of this thread) hit me up in a pm :)
