Snow Tire pressure question
Discussion in 'Prius c Fuel Economy' started by UnSurreal, Nov 29, 2012.
  1. UnSurreal
    UnSurreal Junior Member
    38
    16
    Waterloo Ontario
    I have my all seasons pumped to 42/40, but am switching to winter tires later this week. Is it safe to inflate my winter tires to 42/40 as well?
    wongnog posted this, I'm wondering this as well. =)
  2. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    UnSurreal,
    I don't know where wongnog's post is, but for the both of you, I think it really depends on the max pressure specified on the tire sidewall for the particular brand of winter tire you are using. If your winter tire max pressure on the sidewall is less than 44 lbs, then NO. On the fronts I would use 2 lbs less than your max printed on the sidewall (to allow for a pressure increase as the tire warms up with driving), but still also maintain the 2 lb lower differential to the rear tires.
    Ken (in Bolton,Ct)
  3. james cook
    james cook Member
    145
    36
    Louisiana
    i think winter tires are overrated. our roads het actively cleared here...2 snows so far...
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This sounds like a post from someone who has never driven on ice with really bad summer tires. ;)
    Tom
    poser and Ryephile like this.
  5. james cook
    james cook Member
    145
    36
    Louisiana
    2 winters in minot north dakota.
  6. qbee42
    18,058
    3,074
    Northern Michigan
    Which says nothing about the tires you used.
    Tom
  7. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    This reeks of ignorance. How many current-generation summer, all-season, and winter tires have you actually owned? Winter tires offer markedly improved traction versus all-seasons and especially summer tires on cold roads whether they're clear, wet, slushy, snowy, or icy.
    You may be blessed with magical snow-clearing services, but not all of us are. My commute route is either among the last in the metro to be plowed or simply never gets serviced, so winter tires make a massive improvement in probability of getting to and from work in a safe and timely manner.
    Regarding the OP's question; you typically run winter tires a couple PSI lower to better conform to the uneven snowy surface, kind of like when you run on sand dunes, but not that extreme. It also depends on the percentage of clear/dry road you run on. Well maintained roads merit higher pressure, but if you're in the backwoods of snow country, high 20's to low 30's may be a better solution. As always YMMV.
    poser and F8L like this.
  8. UnSurreal
    38
    16
    Waterloo Ontario
    Got the tires on yesterday - they are 51 Max. I set them at 42/40
  9. homeless
    homeless Junior Member
    MN
    I was thinking the same question as the OP. I got my Michelin XI-2 tires installed just in time for the snow storm last week. Sure glad I did... Minnesota DOT apparently was not watching the weather channel and it took three days to clear the roads. The dealer put 35 PSI, the wall max PSI is 51.. I was gonna inflate to 45, and see how that works. Hopefully it helps the MPG's.... they took a real dump last week.
  10. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Read Ryephile's post.
    Ryephile likes this.
  11. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    Today I inflated my Michelin X-Ice to 40 front/38 rear. Im betting on a remarkable difference in mpg's as all 4 were at 28 psi before I checked them, and I drove a day or two on them that low. Explains my average of 39.5 mpg :eek:
  12. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Wow! You know better. :p
  13. PriusGuy32
    1,417
    510
    Im catching on (slowly but surely, must be all of those lead paint chips I ate as a child, lol) but Im getting there.... :D
    frugaldriver likes this.
  14. PriusGuy32
    1,417
    510
    And an update. I was getting 41.1mpg average on the last tank - I aired up the winter tires like I said, now my average is up to 46.5mpg!!! And its 27f degrees out. This best describes me the past day or two---->:D :cool: (y)
  15. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I always preferred the white chips, but red was good, too. :confused:
    PriusGuy32 likes this.
  16. Mr Incredible
    955
    506
    Neb
    Are you stationed at Minot and have had little prior winter driving experience? If you had ever lived in a place with a lot of ice thrown in with the dry packed snow you would have snow tire tattoos in celebration of them.
    poser and PriusGuy32 like this.
  17. winnertakesteve
    121
    35
    I've got Michelin x ice 4's, which I've inflated to about 35 psi. but when they were put on, my dealership had them inflated to 18psi in the front. Is there ANY circumstance where you'd want it THAT low? Or that much difference to the back tires already at 35psi?
  18. PriusGuy32
    1,417
    510
    Heck no!! Get those babies inflated. I have my Michelin X-Ice's inflated to 42f/40r. Getting 46mpg in Michigan weather and Im a leadfoot :censored:
    winnertakesteve likes this.
  19. poser
    poser Junior Member
    Alberta
    Just got my X-Ice on today, of course its above freezing lol and melting right now, guess the -27 that is called for Jan 19th will make good use of these babies. yup!
  20. PriusGuy32
    1,417
    510
    Cool. I like my X-Ice, although Ive never in my life owned any other snow tire to compare it against. This is my first car that isnt a 4x4 with all terrain tires, lol.
    Our 2010 2wd Escape got stuck in the same path that my Prius whizzed right through during the last snowstorm here. I had my X-Ice tires on and the Escape has Michelin all-terrain tires. I got to (and still do) tease the bf about that :D
