Snow Tire Size
Discussion in 'Gen 3 Prius Main Forum' started by Shank, Oct 11, 2016.
  1. Shank
    Shank Junior Member
    Vermont
    Hello, I picked up a 2010 Prius III yesterday with all season tires but I live in Vermont so I really need snow tires soon. The recommended tire size is 195/65/R15. I have some almost-new snow tires from a car I just sold which are 205/70/R15. Do you think this would work on the Prius? Thanks
  2. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I am not a tire specialist but from past readings on tires, I think the 205/70R15 is too large. The tire height of 195/65 rides 126.75mm vs 143.50mm on the 205/70. The difference is 16.75mm. In general, you don't go oversize it by more than 10% of the original (which is 12.67mm). But then again, this is what I recall from past readings only and I may be wrong. For myself,I wouldn't use it.
  3. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
  4. toyolover
    toyolover Member
    441
    67
    toronto, canada
    If you look at the information from Tirerack below regarding oversizing guides, +5 to 10% is the general rule. When you exceed that allowance, it will affect your speed odemeter readings and also the braking performance. Even if the larger tires do not scratch the wheel wells when you mounted them on, it doesn't mean that it is safe. When you go over bumps, the shock absorbers will be compressed and hence the top of the tires may come to contact with the top of the wheel wells.
    Tire Tech Information - Plus Size Wheels & Tires
    (See the very bottom.)
  5. Shank
    Shank Junior Member
    Vermont
    All great points. Thanks guys.
  6. Mendel Leisk
    38,718
    This question comes up often, and yeah, used oversized tires, 'cause they're on hand, isn't a good idea. Here's a Corolla rim that'll work with snows on a 3rd Prius, very likely with yours too:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
