So. Cal. Tech to Diagnose "Transmission Lock Mechanism" Problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by arkestra, Mar 20, 2009.
  1. arkestra
    arkestra New Member
    On several occasions over the last several weeks, I've had a problem starting my 2005 Prius. I won't go into the details, except to say that on two of those occasions, I got a "transmission lock is abnormal" message, which was the subject of a thread last year. (Ideally, I'd link to the thread here, but they won't let me do that because I do not yet have 5 posts. I will try to insert the link in the "trackback" section below. The thread was "Caution: The transmission lock mechanism is abnormal")
    My regular dealership service dept. has been unable to find any problem (even though I brought it there twice with a hybrid system warning light and the red exclamation mark in a triangle light on). They tested the battery yesterday, and said it was fine. (In case it makes a difference -- I saw on one thread that it could -- I'm sure they did not take out the battery for the test.) At least they didn't charge for anything. I went to another dealership, but the service person seemed uninterested in me giving them my business, basically saying they were unlikely to find anything unless they could duplicate the probelm.
    Can anyone recommend a dealership/service place anywhere in Southern California that has a GOOD master technician who could diagnose the problem?
    Thanks for your help
    n
  2. grand total
    grand total Member
    154
    ON, Canada
    Despite what the service department said it probably is your 12V battery.
  3. Patrick Wong
    18,199
    6,464
    If you have a 2005, and the original equipment 12V battery is still installed, I'd suggest that you replace the battery now and be done with it. You'll probably find that the symptom that you described will go away.
  4. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    I had the same message on my car yesterday. It was definately 100% the 12v battery.
  5. TucsonPrius
    TucsonPrius Member
    167
    Tucson, AZ
    2020 Prius
    As others said, this is a sign that your 12V battery is dying.
    When this happened to me, I picked up a new battery at the Toyota dealership and replaced it myself. Took about 20minutes. If I remember correctly all you need is a 10mm socket with a long (6") extension. The Toyota dealership even took back the old battery for recycling so I didn't have to worry about proper disposal.
    Some people suggest getting an Optima with the belief that is a better battery; I have no idea if they are better or not. I do know that I didn't think it was worth the trouble of getting a conversion kit....
    Thanks,
    Shawn
  6. richard schumacher
    7,663
    1,038
    United States
  7. keith_w
    keith_w New Member
    Los Angeles, CA, USA
  8. arkestra
    arkestra New Member
    thanks for all the responses. after another little problem on saturday morning, i went to my regular dealership and received better service with a new service person. the battery was replaced and, although it's only been a little more than 24 hours, so far, so good. thanks again everyone.
  9. zenMachine
    zenMachine Just another Onionhead
    3,355
    299
    Just came back from a five-day vacation to find the 12V battery dead. Kinda unexpected since we've left SKS on for longer periods before without problem. (The car has 80K on it already.)
    Anyhow, after doing the classic hatch crawl to jump the battery (the car was parked head-first in the garage) this message came up.
    "Caution: There is a problem with the transmission "P" lock mechanism. Park your car on a flat surface, and fully apply the parking brake."
    Is this the same (or a similar) error message as above? Is it correct to assume that this is only a 12V battery issue?
    The wife has taken the car to work so I can't do the Maintenance Mode battery check yet, but I'm hoping it's no more serious than that and that the 12V battery will be recharged enough so she can make it back home to... fix dinner! :)
  10. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    The message comes up whenever the car has tried to apply the parking pawl, but the position sensor shows that the pawl hasn't fully engaged in the expected time. This can happen for numerous reasons, but of course one is that the battery was too flat, or 12V system voltage too low, to allow the motor to drive the pawl forward quickly enough.
    A DTC should have been recorded by the Transmission Control ECU to allow the problem to be properly diagnosed. However, it's probably C2318 Low Voltage Error (Power Supply Malfunction). This DTC is apparently recorded whenever the car is IG-ON and the battery voltage is 9.3V or less, for at least one second.
    Dxta likes this.
  11. Patrick Wong
    18,199
    6,464
    Yes, this is the same error message, and it sounds like your car needs a new 12V battery.
  12. zenMachine
    3,355
    299
    Thanks for the confirm, Patrick.
    Seems like the Optima Yellow Top is a favorite for many PC'ers. Is it significantly better than the Toyota one? Any recommendation on where to buy one?
  13. Patrick Wong
    18,199
    6,464
    Some PC members think so. The following website seems to be a favorite: 12 Volt (12v) Toyota Prius Auxilary Battery for 2004, 2005, 2006, 2007, 2008, 2009 and 2010 with installation kit
    The Toyota battery works well for my purposes, MSRP is $139, and that battery is certainly easier to install because you don't have to replace the battery terminal connectors.
  14. zenMachine
    3,355
    299
  15. Patrick Wong
    18,199
    6,464
    That's great, let me know if your order is accepted at that price. (Most Toyota dealer parts depts will not ship batteries because they are considered hazardous material.)
  16. Larry Ratso
    Larry Ratso New Member
    NYC
    What should I do if the problem with transmission P-lock mechanism warning comes back AFTER I had the dealership replace a weak five year old battery? Don't think the mechanics at the dealership I used were too familiar with this issue.
  17. ChapmanF
    15,106
    Somebody now (the dealer, or you if you have a laptop with Techstream, or a local shop with Toyota experience) should read the trouble codes and freeze frame data from the transmission control ECU, look them up in the repair manual and follow the steps there to determine what the actual problem is. That could also have been done before changing the battery, but you do at least have a new battery now.
    -Chap
