So I cleaned my original cabin air filter....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ajbdiaz, Nov 13, 2009.
  1. ajbdiaz
    ajbdiaz youtube.com/wyldeslash2003
    31
    Thousand Oaks, Ca
    I bought new one to replace it, but I decided to try and clean the original one. It worked so far, but i need your guy's opinions.
    1. I filled a bucket with warm water in the bathtub
    2. I poured in about a quarter cup of dishwashing soap
    3. I swished the water about to get it soapy
    4. I let the filter soak for an hour. why an hour? i was doing errands. you can just check the filter ever 10 minute if you want.
    5. rinse the filter with warm water until there is no more soap coming off it.
    6. let it dry in the sun.
    when i came back the filter was perfectly clean looking... but i still repeated the process to make sure... the water was very black, so the soap and long soak did a great job...
    the second time it looked a little cleaner than before, in my opinion.
    the filter seems to be in tact and still tough feeling and seems to be perfect.
    do you all think it is good enough to put back in the car?
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    Yes
    And when you first start it notice how much easier your prii runs...
  3. patsparks
    10,664
    567
    Adelaide South Australia
    Good procedure for cleaning, think I'll do mine now.
    might be a good idea to knock the filter on a hard surface first and vacuum off loose material before a soak. also run water through the filter from clean side to dirty. Precede this with a spray of surface cleaner to allow dirt to stick to the water.
    One small problem with soaking is some dirt will transfer from the dirty side to the clean via the water, the second wash would have helped this as long as you used fresh soap solution.
  4. uart
    uart Senior Member
    4,215
    1,201
    Australia
    How does the cabin air filter effect how the prius runs?
  5. ajbdiaz
    31
    Thousand Oaks, Ca
    yup, i repeated it again, i thought the same thing you did...
    but my original wasn't super duper dirty, so there wasn't a need to do any vacuuming,
  6. ajbdiaz
    31
    Thousand Oaks, Ca
    UPDATE!!!
    i compared the new one to the washed old one and there is a major difference.
    the new one is stiff and hard to see through, while the old one is floppy and very see through. i dont think it will catch smaller particles.
    i dont think it is worth your time....
    but it was worth a try.....
  7. northwichita
    481
    102
    29
    Wichita KS
    Instead of one big cleaning I do a lot of small ones with an air compressor air chuck about every two months, I have my window down delivering mail on dusty roads. I have a spare one which I haven't had to use yet, so just blowing one out with air seems to work.
    I wasn't sure what the composition was , the answer in this thread.
    http://priuschat.com/forums/gen-ii-...hooting/66748-cabin-air-filter-questions.html
  8. ursle
    ursle Gas miser
    1,049
    192
    NH
    A clogged filter impedes airflow, a severely clogged filter severely impedes airflow. Unless you've got your climate control system turned off the cabin filter is always moving air, a clean filter moves air more efficiently
  9. ajbdiaz
    31
    Thousand Oaks, Ca
    it smells better too...my car has that new car smell again...i didnt think that would happen by changing my CAF
