So I know I shouldn't install HIDs to replace halogens but...
Discussion in 'Gen 2 Prius Main Forum' started by nullxposur, Jan 12, 2010.
  1. nullxposur
    nullxposur Junior Member
    70
    San Antonio, TX
    has anyone actually done it? I mean, without replacing the stock headlamps with HID/DOT-approved headlamps and auto-leveler? As in, just replacing the halogen bulb with an HID ballast/bulb?
    I wonder what your experience has been. Do you get alot of glare like mentioned? Many PO'd drivers flashing their lights? etc
    Curious to know because I read alot of people mention the why's of not doing the upgrade but not many saying they've done and it's worked ok or not at all.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You have to replace the entire headlight housing, including controllers. Halogen and HID are not interchangeable.
  3. PRIUS007
    PRIUS007 James Bond -007
    133
    Mundelein, Illinois
    Get yourself a $60 HID kit off of e-Bay for a 9003 / H4 bulb (same thing) and give it a try. It's a quick simple plug and play set up.
    And what ever you do, don't go buying some kit for $200 just because the vendor says 'theirs is the best'.
    They are all made in the same place, turst me on this one.
    Here is an example of your standard bulb along side ofan hid bulb.
  4. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    what!??!?!?! no you don't....read on....
    don't get a kit with the above type bulb...get a bi-xenon that allows you to keep your hi-beams -- looks like this...
  5. bagwell
    592
    49
    the woodlands, tx
    I bought 2 kits from 2 separate sellers 1 was a 5000K one is 4500K - I like the 4500K much better - the kits were identical - I recommend this ebay seller --eBay My World - zgperformance
    I paid $61 shipped for the kit -- he's a US (CA) seller so you should have it in a few days.
    as for the light output --- its much much brighter -- there is a slight glare but nobody has flashed me, so it can't be too bad.
  6. ski.dive
    ski.dive Active Member
    864
    223
    Hutchinson Island,FL. Mt. Snow,VT
    ````How long does it take to install this kit?
    Is it easy to install, what tools are needed?
  7. bagwell
    592
    49
    the woodlands, tx
    its not too bad...I could probably do it in an hour easy...longer if you've never done it -- very basic tools are required -- there's a how-to on the site somewhere.
    just take your time - its pretty simple really.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    And again, it will not be legal* on public highways in the US, so expect to chat with Officer Friendly.
    *You can't legally change the kind of light (Halogen, LED, HID) using the stock connector. If your individual car already has HIDs, you can change brightness color.
  9. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    I need a quick catch up....
    Im looking to make this switch as well. I have a Gen 3, with standard halogens. this thread is saying "buy x kit, install in place of the standard halogen, it will be illegal but will provide more light" is that correct?
    also bagwell,
    Could I bother you to find the exact auction for the correct bi-xenon bulbs from that seller? Theres a lot of terminology flying around the auctions and its a little confusing figuring out whats what.
    finally, what is the life expectancy of the new bulbs compared to the stock halogens?
  10. hill
    8,068
    Our HID's have been fine for 90K miles, but many have had theirs paid for by toyota for early failure. Keep that in mind. I don't have the TSB handy or I'd post it ... but search around & you'll find it.
  11. bagwell
    592
    49
    the woodlands, tx
    in a Gen III you have cool projector headlights so an HID kit will work great...unfortunately I don't know what bulbs the GEN III takes.
    "4300K" is the stock color temp, I prefer 4500K which provides a slightly whiter lite.
    here's what you need to do - find out the bulb type for the low beams of your car - then go to the seller I mentioned above and search his items for your bulb type.
    oh the life epectancy of HID bulbs is around 3000 hours I believe....much longer than halogen...I've never had a HID bulb burn out.
    I've installed HID kits on my past 3 cars over about 5 years and have never EVER been stopped or questioned.....and I have no worries about it either...had every car inspected tto -- guess what? no issues...
  12. nullxposur
    70
    San Antonio, TX
    bagwell, I actually just bought a kit from zgperformance for my 2010 and I love it!! I'm considering buying a similar for a 2008 in the family as well, but I first wanted to know what others who have done it think so far in regards to glare and such.
    deltron, do an ebay search for "2010 prius hid" and you'll find some decent hits. I went with zgperformance just because they mention exactly that it's a digital ballast, the color temp I want, that it's 35W and not 55W, it's plug and play so no battery connection used, they sell H11 bulbs used in the 2010, and they have a 90-day warranty.
    So for the Gen2, do the 9003/H4 work and how different are they than bi-xenon?
  13. tf4624
    tf4624 Active Member
    526
    51
    Lol u can mod as long as it fits the housing and the beam it set in the right direction
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    What do you mean by this post? Do you mean that it is physically possible to modify a halogen headlight assembly to hold HIDs, or that it is legal to do so?
    As for legal, the answer is no, unless you have the design recertified by the DOT.
    Tom
  15. w202mae
    w202mae Junior Member
    59
    40
    SoCal
    35W is a cheaper ballast kit compared with 50-55W, it's brighter and stronger. I am contemplating to get one for my 2010.
  16. tc_demon
    tc_demon New Member
    Las Vegas, NV
    I expected to receive my HID kit from Xenon Depot on Wed...Are you guys running the positive wire from the rear battery terminal for the kit?
  17. desertrider2215
    156
    usa
    ^Theres no need to run wires to the back--at least for me i didn't need to. I purchased a kit on my own, installed them (plug n play) real simple really, however people were flashing there brights at me..SO I decided to simply lift up the hood and twist the lever which lowers the lights.
    Problem solved! had them in for over a year and a half NO problems whatsoever. ive even driven our other car and had someone drive mine at night and they look completely normal. sure, it may be illegal, but who cares! cops will never know, if done correctly.
    good luck!
  18. tc_demon
    tc_demon New Member
    Las Vegas, NV
    oh okay, because the kit I bought uses the battery and the oem connections to start the ballast...So I guess I have to look on how to run a positive wire from the back to the engine.
  19. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    in the gen3 there is a place in the fuse box under the hood
  20. nullxposur
    70
    San Antonio, TX
    Same for gen2, there's a red battery cable on the fuse box. With some guidance from bagwell, I bought and installed the bixenon lights on a 2008 prius. I must say, they don't look blinding to me. The headlights are in the same position so they don't blind the incoming traffic way too high. I haven't had a problem so far. I even took it on the highway and got no one flashing their lights at me. I'm so glad I got the bixenon because they look so nice when the high beams turn on =D
