So I replaced rear shocks with KYB ExcelG
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cyclopathic, Jul 14, 2014.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    First of all to all who say OEMs don't last: they were fine at 143K.. would come extend back after being compressed the same way as brand new replacements.
    Second ExcelGs are not performance shocks but they are slightly better then OEM. They soak big bumps better, and less body roll in turns.
    Was it worth it? Not really.. but they are better
    Gas Mizer likes this.
  2. WA///M
    WA///M New Member
    Chicago, IL
    Good insights.
  3. Grren4ever
    Grren4ever Active Member
    347
    166
    How much was labor to do the rear shocks?
  4. Mike500
    Mike500 Senior Member
    2,593
    764
    Since the Gen III does NOT use coil over shocks, the installation cost shouldn't cost that much.
    There is a through bolt through the eye bushing on the bottom mount and a nut on the stud that goes into the hatch area accessible at the rear wheel arch.
  5. cyclopathic
    3,292
    547
    2014 Prius c
    at leisurely pace about 1.5hr. It took longest to pop upholstery in trunk just enough to get open end wrench/hex to undo the top, and you need a long 17mm(?) socket and impact for bolt at the bottom.
  6. peterjmc
    917
    188
    Clarksburg, MD
    I agree that the total time is about 1.5 hours for an experienced technician.
    For the 2010-2011 Prius hatchback, you have to deal with taking apart the interior trim and upholstery.
    For the 2012+ Prius hatchback, Toyota has put in access panels (small plastic covers) directly over the interior rear strut bolt to allow for easy access.
  7. cyclopathic
    3,292
    547
    2014 Prius c
    I would not call myself an "experienced technician". If it were someone at dealer it would take them less then a half time as they would have to guess where the pistons are.
    If there were access panels, 10min per shock is all you need. Car doesn't need to be lifted, no wheels to take, no alignment necessary; just drive it on ramp and undo 2 nuts per shock. That if you have long socket, impact and your compressor puts out enough pressure
